Wired Intelligent Edge
  • 1.  PCM 4 No Event log entries for switch
    Posted Apr 04, 2013 03:49 AM
    So I have PCM+v4.00.03.541 and I have 44 switches.  All of the switches have event log entries under the "events" tab except for two.  A 2910al-24poe running 15.0.8.0012 and an 8212zl running 15.09.0012.
    Both of these switches test successful... I can scan device and pull the config file in... I have rediscovered these devices several times and I have even deleted and then rediscovered these two switches.
    I logged into each switch and verified by doing a show logging -r that the switch was in fact logging.  I verified my snmpv1/2 community "public" host address.. all of the default traps are set to enable...
    I am using snmpv3 for write access and like I stated when I test communications all tests pass successfully??
    I don't know what else to check.  Anybody have any ideas why only these two switches aren't populating the event's tab?
    8212zl Running Config (for reference)
    ; J9091A Configuration Editor; Created on release #K.15.07.0008
    ; Ver #02:1b.2f:36
    hostname "CHH-Core-8212"
    time timezone -300
    time daylight-time-rule Continental-US-and-Canada
    ip access-list extended "guest-wireless"
    10 permit udp 0.0.0.0 255.255.255.255 eq 68 0.0.0.0 255.255.255.255 eq 67
    20 permit udp 172.19.8.0 0.0.3.255 172.16.1.21 0.0.0.0 eq 53
    25 permit tcp 172.19.8.0 0.0.3.255 172.16.1.27 0.0.0.0 eq 443
    26 permit tcp 172.19.8.0 0.0.3.255 172.16.1.27 0.0.0.0 eq 80
    30 permit tcp 172.19.8.0 0.0.3.255 172.17.1.34 0.0.0.0 eq 443
    35 deny ip 172.19.8.0 0.0.3.255 172.16.0.0 0.0.255.255
    40 deny ip 172.19.8.0 0.0.3.255 172.17.0.0 0.0.255.255
    50 deny ip 172.19.8.0 0.0.3.255 172.18.0.0 0.0.255.255
    60 deny ip 172.19.8.0 0.0.3.255 172.19.0.0 0.0.255.255
    70 deny ip 172.19.8.0 0.0.3.255 172.20.0.0 0.0.255.255
    75 deny ip 172.19.9.0 0.0.3.255 172.26.0.0 0.0.255.255
    80 permit ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
    90 remark "implicit deny any any"
    exit
    module 1 type J9538A
    module 2 type J9546A
    module 3 type J9534A
    module 7 type J9538A
    module 8 type J9546A
    module 9 type J9534A
    interface C1
    speed-duplex auto-1000
    exit
    interface C2
    name "BJH-1 CL-Cisco Trk100"
    exit
    interface I1
    name "BJH-2 TWC Trk100"
    exit
    interface I2
    name "BJH-3 CL-RAD Trk100"
    exit
    interface I15
    name "Cobra Paging Vlan 130"
    exit
    interface I16
    exit
    interface I17
    exit
    interface I18
    exit
    interface I19
    exit
    interface I20
    exit
    interface I21
    exit
    interface I22
    name "Paging Vlan 101"
    exit
    interface I23
    exit
    interface I24
    name "Paging VOIP VLan 140"
    exit
    trunk C21-C22 Trk5 Trunk
    trunk C23-C24 Trk6 Trunk
    trunk C3,I3 Trk7 Trunk
    trunk C4,I4 Trk8 Trunk
    trunk C2,I1-I2 Trk100 LACP
    ip default-gateway 172.18.1.1
    ip routing
    no ip source-route
    snmpv3 enable
    snmpv3 restricted-access
    snmpv3 group ManagerPriv user "admin" sec-model ver3
    snmpv3 group ManagerPriv user "initial" sec-model ver3
    vlan 1
    name "DEFAULT_VLAN"
    no untagged A1-A8,B1-B8,C1,C5-C20,G1-G8,H1-H8,I5-I24,Trk5-Trk8,Trk100
    no ip address
    exit
    vlan 101
    name "CHH-Servers"
    untagged A1-A8,B1-B8,C5-C14,G1-G8,H1-H8,I5,I7-I11,I13-I14,I22-I23,Trk7-Trk8
    ip address 172.18.1.1 255.255.255.0
    exit
    vlan 102
    name "CHH-Printers"
    ip address 172.18.2.1 255.255.254.0
    tagged A1-A8,G1-G8
    exit
    vlan 103
    name "CHH-1E-Clients"
    ip helper-address 172.18.1.21
    ip address 172.18.6.1 255.255.254.0
    tagged A1-A8,G1-G8
    exit
    vlan 104
    name "CHH-1W-Clients"
    ip address 172.18.10.1 255.255.254.0
    tagged A1-A4,A6-A8,G1-G8
    exit
    vlan 105
    name "CHH-2E-Clients"
    ip address 172.18.14.1 255.255.254.0
    exit
    vlan 106
    name "CHH-2W-Clients"
    ip address 172.18.18.1 255.255.254.0
    exit
    vlan 115
    name "CHH-Radiology"
    ip address 172.18.40.1 255.255.255.0
    exit
    vlan 116
    name "CHH-MedEquip"
    untagged I6
    ip address 172.18.42.1 255.255.254.0
    exit
    vlan 117
    name "CHH-OthEquip"
    ip address 172.18.44.1 255.255.254.0
    tagged A1-A8,G1-G8
    exit
    vlan 121
    name "CHH-Meru-WAP"
    untagged I12
    ip address 172.19.1.1 255.255.255.0
    tagged A1-A8,G1-G8,Trk7-Trk8
    exit
    vlan 122
    name "CHH-Meru-MedEquip"
    ip address 172.19.2.1 255.255.255.0
    tagged Trk7-Trk8
    exit
    vlan 123
    name "CHH-Meru-Track"
    ip address 172.19.3.1 255.255.255.0
    tagged A1-A4,A6-A8,G1-G8,Trk7-Trk8
    exit
    vlan 124
    name "CHH-Meru-Secured"
    ip address 172.19.4.1 255.255.252.0
    exit
    vlan 125
    name "CHH-Meru-Guest"
    ip address 172.19.8.1 255.255.252.0
    ip access-group "guest-wireless" in
    exit
    vlan 126
    name "CHH-Meru-VoWiFi"
    ip address 172.19.12.1 255.255.254.0
    exit
    vlan 140
    name "CHH-Cisco-VOIP"
    untagged C15-C20,I24
    ip helper-address 172.19.100.20
    ip address 172.19.100.1 255.255.248.0
    tagged A1-A8,C14,G1-G8,Trk5-Trk8
    voice
    exit
    vlan 100
    name "BJH-CHH-VLAN"
    untagged C1,Trk100
    ip address 10.7.3.2 255.255.255.252
    exit
    vlan 40
    name "BJH_AVAYA_VOIP"
    tagged A1-A4,A6-A8
    no ip address
    exit
    vlan 60
    name "BJH_Cisco_VOIP"
    voice
    no ip address
    exit
    vlan 130
    name "CHH-Paging"
    untagged I15-I21
    ip address 172.19.80.1 255.255.255.0
    tagged A1-A8
    exit
    vlan 131
    name "CHH-TV"
    ip address 172.19.82.1 255.255.255.0
    tagged A1-A4,A6-A8
    exit
    vlan 95
    name "CRR-CH-to-BJ"
    ip address 172.19.112.1 255.255.255.252
    tagged A1-A2
    exit
    console inactivity-timer 60
    banner motd "\n This is a private system maintained by Harnett Health System.\nUnauthorized or improper use of this system may result in administrative \n disciplinary action and civil and criminal penalties.\n\n\n IF YOU ARE UNAUTHORIZED LOG OFF NOW!\n\n"
    timesync sntp
    sntp unicast
    sntp server priority 1 172.16.1.21
    no telnet-server
    no web-management
    web-management ssl
    ip ssh filetransfer
    ip route 0.0.0.0 0.0.0.0 10.7.3.1
    ip route 10.10.7.0 255.255.255.0 10.7.3.1
    ip route 172.16.0.0 255.255.0.0 10.7.3.1
    ip route 172.17.1.0 255.255.255.0 10.7.3.1
    ip route 172.17.104.0 255.255.248.0 10.7.3.1
    ip route 172.17.112.0 255.255.255.252 10.7.3.1
    ip route 192.168.9.0 255.255.255.0 10.7.3.1
    snmp-server community "public"
    snmp-server host 172.16.1.33 community "public" trap-level critical
    snmp-server enable traps startup-config-change
    snmp-server enable traps running-config-change
    snmp-server contact "Dominic Messer" location "CHH-MDF"
    snmpv3 user "admin"
    snmpv3 user "initial"
    spanning-tree Trk5 priority 4
    spanning-tree Trk6 priority 4
    spanning-tree Trk7 priority 4
    spanning-tree Trk8 priority 4
    spanning-tree Trk100 priority 4
    primary-vlan 101
    no tftp client
    no tftp server
    redundancy management-module nonstop-switching
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    password manager
    password operator
    #PCM
    #snmp
    #event
  • 2.  RE: PCM 4 No Event log entries for switch
    Posted May 27, 2013 11:30 AM
    Remove this from the config:
    Does that change the picture?
  • 3.  RE: PCM 4 No Event log entries for switch
    Posted Aug 27, 2013 09:16 AM
    To fix this problem I had to use the IP address of the primary VLAN to discover this switch.  If I used the the IP address assigned to the default VLAN the device would be discovered by no syslog messages would be delivered.  I noticed with a different syslog server that events were coming from the IP address assigned to my primary VLAN not my "management" VLAN.  Once I did a manual discovery with the primary VLAN IP address syslog messages were populated just fine.
