I installed PCM 4 to monitor our HP Procurve switches.
We've got 6 switches from which only 2 PCM receives data. On the 4 switches PCM isn't able to collect data, the message Poll port error (verify device is discovered correctly).
The 4 switches are all Procurve 2524 switches running versions F.04.08 and F.05.17 of the firmware.
One of the switches that can be polled correctly is also a Procurve 2524, but is running version F.05.72 of the firmware.
The 6th switch is a different model.
Could it be possible that due to the older firmware versions that PCM can't poll the switches?
If so, can I easily without problems update the switches to the latest firmware version from PCM?
