PEF-NG License on Master-Local
  • 1.  PEF-NG License on Master-Local
    Posted Jul 06, 2017 09:03 AM
    I am sudying for ACMP 6.4. Im not sure about a scenario.
    If I have a Master-Local environment without centralized licensing enabled,..and all APs terminate to Local Controller.
    Where should I install PEF-NG License for Roles and Policies to be applied?
    Should I install it to Master and all Local?
  • 2.  RE: PEF-NG License on Master-Local
    Posted Jul 06, 2017 09:04 AM
    You need PEF-NG on the master to configure policies and PEF-NG on the local to enforce them.  If you can turn on centralized licensing, you should..
