PEFV on VMC
  • 1.  PEFV on VMC
    Posted Jan 08, 2019 03:15 AM
    Hi Team,
    Do we support PEFV functionality on virtual mobility controllers? If so then how to we size the virtual controller to reflect corresponding PEFV license such as LIC-7005-PEFV, LIC-7008-PEFV etc. as VMC only comes in 4 variants MC-VA-10/50/250/1K??
    Many thanks in advance!!
    Manish
  • 2.  RE: PEFV on VMC
    MVP EXPERT
    Posted Jan 08, 2019 03:31 AM
    It is supported and you would base it on the total number AP's using a  PEF-LIC within the environment.
  • 3.  RE: PEFV on VMC
    Posted Jan 08, 2019 06:26 AM
    Many thanks for the prompt response. So when you say I should base it on no. of AP's using PEF-LIC do you mean the PEF firewall license or was it a typo and you meant PEFV VPN license?
    Basically my scenario is to use this virtual controller only as a VPN concentrator with multiple BOC's and VPN users across geo location.
    Many thanks!!
  • 4.  RE: PEFV on VMC
    MVP EXPERT
    Posted Jan 08, 2019 06:31 AM
    Ah sorry, I mis-read it! In that case the PEFV is a single license which is applied to the MD. So this is a single license per controller.
    For example :
    Aruba LIC-7005-PEFV Controller Policy Enforcement Firewall for Aruba 7005 Controller License E-LTU
    The license capacity scales to the controller user capacity
  • 5.  RE: PEFV on VMC
    Posted Jan 09, 2019 03:35 AM
    Licensing for VIA VPN has moved to a per concurrent connection license:
    JZ148AA Aruba LIC-VIA Per VIA Client Controller VPN License E-LTU
    This replaces the PEFV license, which is still orderable.
    Please work with your Aruba Partner or Aruba account team to get the right licenses quoted for your deployment.
