Per-user bandwidth limiting introduces latency? IAP-105
  • 1.  Per-user bandwidth limiting introduces latency? IAP-105
    Posted Apr 09, 2014 02:13 PM
    Hi all,
    We have several buildings with between 10-40 Aruba IAP-105 access points, functioning in virtual-controller mode to provide wireless access.  Recently, due to some malware incidents overloading an access point, I have been experimenting with per-user bandwidth controls to limit how much traffic an individual can use.  I started out with what I thought was a very liberal setting of 1Mbps down and 768kbps up (consider that each building has a 100Mbps down/20Mbps up link to the Internet, in an educational environment).
    After testing, the speed-tests come back and show that bandwidth limits are functional.  However, I'm getting complaints that seem to be latency-related.  Loading a streaming video on a popular website like YouTube might take 15-30 seconds before the video starts playing, and sites seem to be slow to load.  I have since gone to 1280kbps down/768kbps up, and I get bandwidth changes, but still hear about issues with latency.
    I don't want to up the bandwidth-per-user on our Student SSID much, but I need to figure out if others have experienced this issue.  Have you found it is better to rate-limit your users in other ways?  I could examine doing it at our firewall, but my idea of doing it at the access point level was so that an access point wouldn't be overloaded by a few users hogging it or having an infected system.
  • 2.  RE: Per-user bandwidth limiting introduces latency? IAP-105
    Posted Apr 09, 2014 03:21 PM
    What code version are you running?
  • 3.  RE: Per-user bandwidth limiting introduces latency? IAP-105
    Posted Apr 09, 2014 10:23 PM
    When this started, I was on 6.2.xx, but I'm now on 6.3.1.2-4.0.0.4_42384.
  • 4.  RE: Per-user bandwidth limiting introduces latency? IAP-105
    Posted Aug 25, 2014 01:59 PM
    Hi! I'm using only a few IAP-105s tied together by the virtual controller to provide corporate and guest WIFI access. I'm interested in limiting bandwidth but I must be missing something in the console because I'm not seeing if/how I can configure it.
    Could you maybe point me in the right direction to locate the per-user controls you refer to in your post?
    Many thanks!
  • 5.  RE: Per-user bandwidth limiting introduces latency? IAP-105
  • 6.  RE: Per-user bandwidth limiting introduces latency? IAP-105
    Posted Aug 26, 2014 10:03 AM
    Thanks boneyard! That worked perfectly. Now I can start starving the leaches!  =D
  • 7.  RE: Per-user bandwidth limiting introduces latency? IAP-105
    Posted Aug 26, 2014 12:05 PM
    you are welcome, be sure to use the accept as solution button to flag this question as answered.
