per user session number
  • 1.  per user session number
    Posted Jun 28, 2013 04:27 AM
    We have an Aruba controller in which we use sattefull firewal.
    However since it keep sessions; in presence of a syn flood, the session table reaches its capacity and other users are not able to use the system untill the flood ends. Is there a way to limit the maximum sessions based on source IP.
  • 2.  RE: per user session number
    MVP EXPERT
    Posted Jun 28, 2013 05:05 AM
    There might be a better way of doing this however I know you can limit the session limit based on the user role. This configures a maximum number of sessions per user in this role. The default is 65535. You can configure any value between 0-65535.
    Configuration -> Access Control -> Security User Roles then edit the Max Sessions under the role.
  • 3.  RE: per user session number
    Posted Jun 28, 2013 08:34 AM
    Where is this syn flood coming from?  Is it coming from a user or external device?
  • 4.  RE: per user session number
    Posted Jun 28, 2013 08:55 AM
    Hello
    Both is possible.
