Performance tuning of cppm to support switch collectors
  • 1.  Performance tuning of cppm to support switch collectors
    MVP EXPERT
    Posted Jan 24, 2024 09:55 AM
    cppm 6.11.5
    2930 switches WC.16.11.13
    Have about  1500 switches all configured to support device fingerprinting  using http,dhcp,lldp collectors.  Client DHCP lease time  is 2 days.
    Each switch has 2 cppm vips defined as radius servers.  fingerprint update times range from 60 secs to  default of 120 secs
    Given that  the switches are using  http(s) to upload data to the cppm VIPs, and. fact that  default max concurrent  http sessions per cppm server  is 1500 ......
    1). What , on the cppm server do you enable to debug fingberprint uplod using this method ( NOT packet capture on network interface when you have a UDP forwarder)
    2). Is there any performance tuning I should be doing on the cppm servers  to cope with the  collector info from the estate ? ( increase max concurrent  https sessions ?)
    A
  • 2.  RE: Performance tuning of cppm to support switch collectors
    Posted Feb 12, 2024 07:07 AM
    I'm not aware of required tuning. I'd expect the HTTPS connection to send an update (every 60-120s) then disconnect again, so number of concurrent connections should not be that high.
    Did you experience issues?? Or is it just before you experience issues? If you need a better answer, it may be good to verify with TAC.
  • 3.  RE: Performance tuning of cppm to support switch collectors
    MVP EXPERT
    Posted Feb 12, 2024 10:41 AM
    Was more a preventative measure, had some issues with devices obtaining ip via dhcp not being fingerprinted by cppm. Everything was fine with low volume of switches, just had occasional issues when we got near the 1000 switch mark with fingerprint update every 60 secs. Have switched to default 120 sec update
    Sent from my iPhone
  • 4.  RE: Performance tuning of cppm to support switch collectors
    Posted Feb 13, 2024 02:47 AM
    In the case that you hit occasional issues with 1000 switches and 60 second reporting time, and that was resolved by changing to 120 second reporting time (basically cutting the load in half), if you have time and opportunity please report to Aruba support such that they and engineering can better understand the limits and scaling. I don't have 1500 switches to test/replicate with.
  • 5.  RE: Performance tuning of cppm to support switch collectors
    MVP EXPERT
    Posted Feb 13, 2024 03:45 AM
    Will do
    Also, if you have multiple cradius servers defined on a switch and they’re all clearpass servers , does the fingerprinting process send data to all of them?
    I define all switch radius servers as being clearpass ones … but do you actually need to do that ?
    On a switch my normal two radius server definitions are cppm VIPs to the same cluster , so my config pulls the same root ca down twice
    Just wondered if I need to define both as cppm appliances
    A
    Sent from my iPhone
  • 6.  RE: Performance tuning of cppm to support switch collectors
    Posted Feb 13, 2024 09:18 AM
    ClearPass would need to receive profiling data only once. When profiling data is received, it's sent for processing (I think one node in the cluster will be dedicated profiler node), then it's updated through the publisher and synced back to each of the subscribers.
    Not sure if the switch will send the data to all ClearPass servers, or to just one, if multiple clearpass servers have been defined.
  • 7.  RE: Performance tuning of cppm to support switch collectors
    MVP EXPERT
    Posted Feb 13, 2024 09:35 AM
    Ok so in our 4 node cluster we have the master publisher set as the primary server for “Server role in zone” and the other 3 cluster nodes don’t have anything defined for server role in zone.
    All the switches use 2 cppm VIPs in their radius servers which point to subscriber cluster nodes
    So the switches would be sending fingerprint data to two of the subscriber nodes
    A
  • 8.  RE: Performance tuning of cppm to support switch collectors
    Posted Feb 13, 2024 10:21 AM
    I don't know if switches will send profiling data to both defined ClearPass nodes, or to one (and use the other when it fails).
    But regardless, the subscriber receiving the fingerprint info should send it to the primary profiling server (on publisher), which processes the information and updates it in the publisher (local for the profiling server as it runs on the publisher) database, and the update is then replicated back to each of the subscribers.
