I was wondering about persistent and backup ssids and are they only available exclusively for RAPs or normal APs provisioned as RAPs? Can I set this on a CAP, beit with cpsec and bridge mode?
Normally with a bridge ssid using dot1x auth for clients, the controller still handles the dot1x stuff, and all other traffic is bridged.
If the ssid is persistent, as is recommended for dot1x, does this mean that the dot1x stuff is also bridged, or is it that the auths start to be bridged as well when the controller is unreachable?
What about persistent dot1x, controller down and clients roaming? Are the master keys, or whatever they are, still distributed amongst APs, or will a roaming client cease to work?
