personal hotspot client history?
  • 1.  personal hotspot client history?
    Posted Jan 27, 2016 05:15 PM
    In Airwave I've found the personal hotspot, and I can see the client currently associated with it.
    I'd like to look at the last few months and see what other clients might have associated over the period. So far I'm missing where that data might be.
    If there isn't a screen in Airwave showing it, any thoughts on what to search syslog for?
  • 2.  RE: personal hotspot client history?
    Posted Jan 27, 2016 06:20 PM
    Is it possible that your data retention policy  is showing you limited information.  Or, that the access points did not scan much on the channel that the hotspot was on?  When you look in that report, you pretty much see everything...
  • 3.  RE: personal hotspot client history?
    Posted Jan 29, 2016 05:33 PM
    I was coming to that conclusion when I posted - hoping that someone could tell me that there was a syslog entry telling about neighbor-client observed on SSID such-and-such, or some other tidbit.
