last person joined: 5 hours ago
phones unable to connect to wireless
  • 1.  phones unable to connect to wireless
    Posted Sep 15, 2016 03:55 PM
    I have a section of a building with T105's and a controller that is having trouble connecting phones to the wireless.  They tell me that the wireless doesn't work.  Nearby I'm seeing wireless signal levels no lower than -64db.  I've turned on user debugging to see if I can figure out what's going on.  What's the best way to debug this?
  • 2.  RE: phones unable to connect to wireless
    MVP
    Posted Sep 16, 2016 04:42 AM
    Not sure what a T105 is. But if on an Aruba controller, see below.
    Are you sure the phones aren't connected? They might be connected but not getting an ip address. Check the station-table for the missing clients.
    show station-table verbose
    If that doesn't help, what kind of security are they using? dot1x, psk or other?
    Checking the logs for possible clues.
    show log errorlog 50
    show log user 100
    Next start up a user-debug, that should more than likely pop up a few hints as to what is going wrong.
    configure terminal  logging level debugging user-debug <mac>
    show log user-debug 100
    show auth-tracebuf
    If that still doesn't help you resolve the issue, get back here with that output and some more info about your setup and we might be able to help. If urgent, open a support case at the same time.
