Hi,How are the phy rate of the link calculated ? .What is the relaiabilty of phy rate or instead do we need to run a throughput test ? .If phy rate shows of an ac adpter shows 870 Mb , Does it mean it support 2x2 spatial streams Thanks
Hi - You've posted the same question 3 times. There answer is in your original post:
http://community.arubanetworks.com/t5/Wireless-Access/Phy-rate-vs-Throughput/td-p/258134
Sorry . I was getting someerror when i was posting the question .I thought it was'nt posted
Thannks
