Ping and discover wireless clients.
  • 1.  Ping and discover wireless clients.
    Posted Dec 05, 2012 06:18 PM
    I have installed two Iap-105's in one of our branch offices, they seem to work well.
    The one thing I dont understand is that I cannot ping any of the wireless clients from the wired network.
    I have used GFI Languard for quite a while to see who is on the network from at any given time. It cannot see any of the wireless clients either.
    I am not pinging by name I am using the IP address that I see the AP has assigned each client.
    Of course it is on a different subnet eg .
    Office subnet would be 192.168.3.xxx/24 and WIreless clients are given adresses by AP's DHCP server like 192.168.15.xxx/24.
    Should I be able to ping them or not?
    Is there a way to discover them on the network with some type of network managment tools?
    Any thoughts appreciated.
  • 2.  RE: Ping and discover wireless clients.
    Posted Dec 05, 2012 08:03 PM
    If the wireless networks for those clients on IAP are "Virtual controller Assigned", they are in a subnet that is natted and behind the IAP, and you should not be able to ping them.  If the wireless network is "Network Assigned" you should be able to ping.
  • 3.  RE: Ping and discover wireless clients.
    Posted Dec 05, 2012 09:36 PM
    Thanks, Yes they are VIrtual controller assigned.
    I understand now.
    Is there a way to enable remote access software to connect in this configuration.
    I.e., I use Microsoft Remote Assitant to help users with problems.
    I cannot seem to do this with the VIrtuall Controller assigned addresses.
    I did not want to use network assigned addresses because we have a limited amount of addresses available for DHCP on our LAN subnet.
    Regards
    Mario
  • 4.  RE: Ping and discover wireless clients.
    Posted Dec 05, 2012 09:37 PM
    Do you have firewall policies attached to that user?
  • 5.  RE: Ping and discover wireless clients.
    Posted Dec 06, 2012 03:50 PM
    If you mean the Firewall incorporated in the device then no there are no rules created for the user.
  • 6.  RE: Ping and discover wireless clients.
    Posted Dec 06, 2012 11:45 PM
    Please open a support case.
