  • 1.  Ping AP
    Posted Jun 26, 2014 04:13 AM
    Hi Community,
    Is it possible for me to ping AP from different subnet? This is for monitoring purposes.
    Thanks in advance
  • 2.  RE: Ping AP
    Posted Jun 26, 2014 04:53 AM
    if you have routing reachability should be fine
  • 3.  RE: Ping AP
    Posted Jun 26, 2014 09:01 PM
    @Islam
    How about, is there a specific OID for monitoring that shows AP status and AP client per AP?
  • 4.  RE: Ping AP
    Posted Jun 27, 2014 07:43 AM
    If you are trying to monitor, it is best to monitor using SNMP and not PING in both cases (Controller or Instant).
    Instant requires IAP version 4.1 for SNMP to work
    If you have a MIB browser, download the MIB and the MIB guide and you will be able to locate them both.
    For the AP status, the OID is the following:
    .1.3.6.1.4.1.14823.2.2.1.5.2.1.4.1.19
    After 19, you will need to enter in the decimal format of the MAC address of the AP, it will then return something like so
    .1.3.6.1.4.1.14823.2.2.1.5.2.1.4.1.19.xxx.243.127.yyy.153.236 = INTEGER: 1
    1 = AP is UP
    2 = AP is DOWN
    For example, if your MAC address was, DE:AD:BE:EF:CA:FE, the corresponding decimal format would be .222.173.190.239.202.254
    So you would perform the following command:
    snmpwalk -v2c -On -c <community_string> IP_of_controller:<snmp_port> .1.3.6.1.4.1.14823.2.2.1.5.2.1.4.1.19.222.173.190.239.202.254
     You would then receive the response of 1 or 2.
    How to convert decimal to MAC and MAC to Decimal, here is something I wrote in Python that will do the work for you.
    #!/usr/bin/env python
    import sys
    def hex2dec(s):
        return int(s, 16)
    def dec2hex(s):
            print "s = " + s
            mac = hex(s)[2]+hex(s)[3]
            return mac
    def mac2oid(mac):
        oid = ""
        for byte in mac.split(':'):
            oid += ".%s" % hex2dec(byte)
        return oid.strip()
    def oid2mac(oid):
            mac = ""
            for byte in oid.split('.'):
                    #for i in range(len(byte)):
                    #       t = int(byte[i])
                    mac += ".%s" % dec2hex(byte)
            return mac.strip()
    menu = """
    Please choose how you want to convert your string
        (1) Convert from MAC 2 OID
        (2) Convert from OID 2 MAC
    while True:
            choice = raw_input(menu)
            if "1" in choice:
                    macstr = raw_input("Enter MAC:")
                    print mac2oid(macstr)
            elif "2" in choice:
                    oidstr = raw_input("Enter OID - format(xxx.yyy.zzz.aaa.bbb.ccc): ")
                    print oid2mac(oidstr)
    Hope this helps.
