On the Switch 6300m.(two switches connected with VSF)
Ver : ArubaOS-CX_6400-6300_10_10_1020
PC2(10.10.20.1) connect to 1/1/5,
PC3(10.10.30.1) connect to 1/1/6,
1. Each PCs ping reaches the gateway.
2. However, ping fails up to the other gateway and PC
3. On the 6300m switch, ping reaches both PCs.
The setting value is as follows.
6300(config)# sh ip interface br
Interface IP Address Interface Status
link/admin
vlan1 No Address down/up
vlan20 10.10.20.254/24 up/up
vlan30 10.10.30.254/24 up/up
6300(config)# sh inter vl 20
Interface vlan20 is up
Admin state is up
Description:
Hardware: Ethernet, MAC Address: bc:d7:a5:b3:35:c0
IPv4 address 10.10.20.254/24
L3 Counters: Rx Disabled, Tx Disabled
6300(config)# sh inter vl 30
Interface vlan30 is up
Admin state is up
Description:
IPv4 address 10.10.30.254/24
6300(config)# sh ip route
Displaying ipv4 routes selected for forwarding
Origin Codes: C - connected, S - static, L - local
R - RIP, B - BGP, O - OSPF
Type Codes: E - External BGP, I - Internal BGP, V - VPN, EV - EVPN
IA - OSPF internal area, E1 - OSPF external type 1
E2 - OSPF external type 2
Flags: F - FIB-optimized route
VRF: default
Prefix Nexthop Interface VRF(egress) Origin/ Distance/ Age
Type Metric
10.10.20.0/24 - vlan20 - C [0/0] -
10.10.20.254/32 - vlan20 - L [0/0] -
10.10.30.0/24 - vlan30 - C [0/0] -
10.10.30.254/32 - vlan30 - L [0/0] -
Total Route Count : 4
6300(config)#
6300(config)#sh run
interface 1/1/5
no shutdown
no routing
vlan access 20
interface 1/1/6
no shutdown
no routing
vlan access 30
Is there a command like 'ip routing'?
so please give me a solution.
Thanks.
