Hi guys!
I have problems with ping -r command. I ping a host out of my LAN and want to know the record for this request. Is not working! Do you know why ?
<CORE>ping -r 192.168.38.95
PING 172.18.38.95: 56 data bytes, press CTRL_C to break
Reply from 192.168.38.95: bytes=56 Sequence=0 ttl=124 time=20 ms
Reply from 192.168.38.95: bytes=56 Sequence=1 ttl=124 time=17 ms
Reply from 192.168.38.95: bytes=56 Sequence=2 ttl=124 time=15 ms
Reply from 192.168.38.95: bytes=56 Sequence=3 ttl=124 time=18 ms
Reply from 192.168.38.95: bytes=56 Sequence=4 ttl=124 time=17 ms
--- 192.168.38.95 ping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 15/17/20 ms
<CORE>
The system version is:
<CORE>dis version
HP Comware Platform Software
Comware Software, Version 5.20.105, Release 6708-US
Thanks!!!
#ping
