Pinging the controller on wired device
  • 1.  Pinging the controller on wired device
    Posted Sep 24, 2020 12:43 PM
    I'm having a strange issue where if I ping my 7205 controller from a wired device I'm getting a large number of drops. If I ping from a wireless device it looks fine. If I ping any other devices from the wired device those pings look fairly good as well. The AOS is 8.5.0.4 and I have two controllers in a VRRP setup. I tried disabling STP to see if that was causing issues but the same thing.
    Thank You,
    Marc
  • 2.  RE: Pinging the controller on wired device
    Posted Sep 24, 2020 03:37 PM
    Try a different wired device.
  • 3.  RE: Pinging the controller on wired device
    Posted Sep 24, 2020 07:30 PM
    I tried a few different servers (physical, virtual) and from different vlans. Some other steps I tried: switching interfaces on the controller and a different cable. I also isolated the switches coming in on the core switch to check for a possible loop. The interface is a trunk port with 3 vlans on it. Some users are dropping connections I assume these issues are related?
    Marc
  • 4.  RE: Pinging the controller on wired device
    Posted Sep 24, 2020 08:29 PM
    Plug into a wired interface on the controller and ping from there.
  • 5.  RE: Pinging the controller on wired device
    Posted Oct 06, 2020 02:10 PM
    cjoseph,
    Thanks for your help turned out we had a user plugged in their voip phone using 2 ports causing a loop!
