Plan tool embedded / 3D ?
  • 1.  Plan tool embedded / 3D ?
    Posted Feb 23, 2012 11:27 AM
    I'm trying to use the plan tool embedded in the W3400  (6.1.3.0) controller.
    A stupid question: I've to define floors, but does the algorithm knows my AP doesn' t work in 2D but in 3D when the tool optimize AP places ?
    Just because the concentric circles seems to be 2D only (*) ... and the optimized placement seems ... 2D also
    Thanks again ... and sorry for my bad english ...
    (*) we don't see circles in the upper or lower floors of the AP
  • 2.  RE: Plan tool embedded / 3D ?
    Posted Feb 27, 2012 08:54 PM
    @criecm wrote:
    There is no 3d planning in the controller-based planning tool, unfortunately.
  • 3.  RE: Plan tool embedded / 3D ?
    Posted Mar 01, 2012 10:00 AM
    No 3D plan tool ?
    I found an answer to my question in the ArubaOS User guide, Chapter 3 - RF plan, p83 :
    "Inter-floor Height" : this is the distance between floor surfaces... RF Plan uses the inter-floor height to allow APs on one floor to service users on adjacent  floors ..."
    So it seems to be like a 3D plan tool, isn'it ?
  • 4.  RE: Plan tool embedded / 3D ?
    Posted Mar 01, 2012 11:47 AM
    with RF plan you can see inter-floor coverage if you mark some references in each floor. if you want to see the coverage in floor 2 of the ap placed in floor 1 and so on..
    I dont know about 3D plan tool but if you want to know inter-floor coverage you can do it with RF plan.
