last person joined: 9 hours ago
planning tab disapeared after firmware upgrade
  • 1.  planning tab disapeared after firmware upgrade
    Posted Apr 07, 2014 11:17 AM
    Hello
    I've upgraded from 6.1.3.9 to 6.3.1.3 recently. And now I can't see the plan tab where i can localize the APs over a map.
    I've already cleared cache of firefox.
    Anybody know which could be the problem?
    Thanks a lot
  • 2.  RE: planning tab disapeared after firmware upgrade
    Posted Apr 07, 2014 11:18 AM
    RF Plan was removed from the controllers in version 6.3.
    From the release notes:
  • 3.  RE: planning tab disapeared after firmware upgrade
    Posted Apr 07, 2014 11:33 AM
    Hello Tim,
    I'm in shock! Then how can I note where are the APs positioned?
    The only way to do that now is to buy Airwave?
    I've been looking on the screenshoots of the 6.3 user guide, and I keep seeing there the tab plan next to maintenance, but maybe they are outdated.
    What a pity
  • 4.  RE: planning tab disapeared after firmware upgrade
    Posted Apr 07, 2014 11:36 AM
    Don;t be shock this was stated in the release notes, and you are right to either use Airwave or to use 6.2.X.X AirOS.
  • 5.  RE: planning tab disapeared after firmware upgrade
    Posted Apr 07, 2014 12:05 PM
    Is true
    I didn't know they were refering to whe whole plan tab. I thought RF plan was refering only to the part where you can plan the APs needed on a deployment defining boundaries and service qualities.
    In my case the upgrade to 6.3 was mandatory to be able to use AP225 so it will be AirWave or plain old printed maps.
    In my opinion this is a pretty basic feature that should be included by default. I hope that this deprecation is in order to move the basic plan feature to the aruba dashboard.
    Allthought thanks a lot for the information.
    Regards
    #AP225
  • 6.  RE: planning tab disapeared after firmware upgrade
    Posted Apr 07, 2014 11:25 AM
    Yes, it is no longer available.
  • 7.  RE: planning tab disapeared after firmware upgrade
    Posted Apr 07, 2014 12:08 PM
    You should relay these thoughts to your account team. We're all just engineers :)
  • 8.  RE: planning tab disapeared after firmware upgrade
    Posted Apr 07, 2014 12:20 PM
    Correct, I didn't mean to offend.
    Regards
