Comware
  • 1.  Please advise if my settings for MSTP are correct
    Posted Dec 16, 2020 07:53 AM
    I am trying to build a network using MSTP on HPE OfficeConnect 1920, as follows:
    https://yadi.sk/i/dOlxH_swp47PmQ
    RI1
    spanning-tree mst priority 0 8192
    spanning-tree mst instance 1
    spanning-tree mst priority 1 8192
    spanning-tree mst instance 2
    spanning-tree mst priority 2 16384
    EI1
    spanning-tree mst priority 0 16384
    spanning-tree mst priority 1 4096
    spanning-tree mst priority 2 8192
    WI1
    RI2
    spanning-tree mst priority 1 16384
    EI2
    spanning-tree mst priority 0 32768
    spanning-tree mst priority 2 4096
    WI2
    RI3
    EI3
    WI3
    spanning-tree mst priority 0 4096
    spanning-tree mst priority 2 32768
    #MSTP
  • 2.  RE: Please advise if my settings for MSTP are correct
    Posted Dec 17, 2020 04:01 PM
    Hi @vmuhanov !
    In my opinion "correctness" of a configuraiton should be measured against the target. There is only one thing that really matters - what is your idea about this network, how do you want it to work. It's you who decides what is needed. If a configuration does what you want, it is correct. It may be not optimal, not scalable, but it will be correct if correctness is all you care about.
    Will this configuration work? Yes, MSTP will take care and provide you the loop-free network. Is this design optimal - the whole idea of building relatively large (outside small office) network using L2 access swithes seems very questionable to me, but you are the one who takes the decision, if you want to go this way, good luck. In overall your picture reminds me one famous article by Petr Lapukhov - https://blog.ine.com/2008/09/24/mstp-tutorial-part-ii-outside-a-region Is it the source of your network design inspiration? (-: If those clouds are regions like in Petr's article I hope you understand that from 6 inter-region links you will have only 2 links forwarding. But in overall it should work and MSTP is definitely the least problem of this network (-:
  • 3.  RE: Please advise if my settings for MSTP are correct
    Posted Dec 21, 2020 08:30 AM
    Right, I used the article by Petr Lapukhov as a basis.
    But the priority assignment is that what remains unclear for me.
    To assign priorities I used the following:
    Let RI1 be the root for instance 0
          WI2 be the root for instance 1
           EI3 be the root for instance 2
    Then the priorities can be assigned according to diagrams as follows:
    #MSTP
