Wired Intelligent Edge
last person joined: 2 hours ago
Please help add aruba switch (2930f and 5406zl) to HPIMC
  • 1.  Please help add aruba switch (2930f and 5406zl) to HPIMC
    Posted Jan 21, 2020 02:27 AM
    Hello everybody,
    Is now, I need to add some HP Switch (Aruba 2930F and Aruba 5406) to HPIMC. But when add have an error
    On Aruba 2930F:
    I sure, ssh username and password are correct.
    With HP 5406ZL
    And  this is my config on Aruba 2930F:
    Running configuration:
    ; JL253A Configuration Editor; Created on release #WC.16.03.0005
    ; Ver #10:08.3f.ff.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:7e
    hostname "m_b3.1_a1"
    module 1 type jl253a
    aruba-central disable
    no rest-interface
    trunk 25-26 trk22 lacp
    trunk 27 trk32 lacp
    igmp lookup-mode ip
    logging 10.129.50.248 udp 10001
    logging origin-id hostname
    timesync sntp
    sntp unicast
    sntp server priority 1 10.129.50.10
    sntp server priority 2 10.129.50.11
    no telnet-server
    time daylight-time-rule western-europe
    time timezone 420
    no web-management
    ip default-gateway 10.129.188.1
    interface 25
    name "-i- m_b_dc_c"
    exit
    interface 26
    name "-i- m_b_dc_c"
    exit
    interface 27
    name "-i- m_dr_c"
    exit
    snmp-server community "kafka" operator
    aaa authorization commands local
    aaa authentication local-user "abc" group "Level-15"
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1-24
    untagged 28,Trk22,Trk32
    no ip address
    exit
    vlan 192
    name "MEDIA-NET"
    untagged 1-21,23-24
    tagged 22,Trk22,Trk32
    ip address 192.168.195.22 255.255.252.0
    ip igmp
    no ip igmp querier
    ip igmp version 3
    exit
    vlan 410
    name "Mgmt"
    tagged Trk22,Trk32
    ip address 10.129.188.13 255.255.255.0
    exit
    vlan 1000
    name "CASINO-NET"
    tagged Trk22,Trk32
    no ip address
    exit
    spanning-tree
    spanning-tree 1 admin-edge-port
    spanning-tree 1 bpdu-protection
    spanning-tree 2 admin-edge-port
    spanning-tree 2 bpdu-protection
    spanning-tree 3 admin-edge-port
    spanning-tree 3 bpdu-protection
    spanning-tree 4 admin-edge-port
    spanning-tree 4 bpdu-protection
    spanning-tree 5 admin-edge-port
    spanning-tree 5 bpdu-protection
    spanning-tree 6 admin-edge-port
    spanning-tree 6 bpdu-protection
    spanning-tree 7 admin-edge-port
    spanning-tree 7 bpdu-protection
    spanning-tree 8 admin-edge-port
    spanning-tree 8 bpdu-protection
    spanning-tree 9 admin-edge-port
    spanning-tree 9 bpdu-protection
    spanning-tree 10 admin-edge-port
    spanning-tree 10 bpdu-protection
    spanning-tree 11 admin-edge-port
    spanning-tree 11 bpdu-protection
    spanning-tree 12 admin-edge-port
    spanning-tree 12 bpdu-protection
    spanning-tree 13 admin-edge-port
    spanning-tree 13 bpdu-protection
    spanning-tree 14 admin-edge-port
    spanning-tree 14 bpdu-protection
    spanning-tree 15 admin-edge-port
    spanning-tree 15 bpdu-protection
    spanning-tree 16 admin-edge-port
    spanning-tree 16 bpdu-protection
    spanning-tree 17 admin-edge-port
    spanning-tree 17 bpdu-protection
    spanning-tree 18 admin-edge-port
    spanning-tree 18 bpdu-protection
    spanning-tree 19 admin-edge-port
    spanning-tree 19 bpdu-protection
    spanning-tree 20 admin-edge-port
    spanning-tree 20 bpdu-protection
    spanning-tree 21 admin-edge-port
    spanning-tree 21 bpdu-protection
    spanning-tree 22 admin-edge-port
    spanning-tree 22 bpdu-protection
    spanning-tree 23 admin-edge-port
    spanning-tree 23 bpdu-protection
    spanning-tree 24 admin-edge-port
    spanning-tree 24 bpdu-protection
    spanning-tree Trk22 priority 4
    spanning-tree Trk32 priority 4
    spanning-tree priority 15
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    no dhcp tr69-acs-url
    password manager
    password operator
    Please help me fix this problem.
    Thanks and regards,
  • 2.  RE: Please help add aruba switch (2930f and 5406zl) to HPIMC
    MVP GURU
    Posted Jan 21, 2020 04:24 AM
    @voducduy wrote:
    Hello everybody,
    On Aruba 2930F:
    With HP 5406ZL
    no rest-interface
    trunk 27 trk32 lacp
    igmp lookup-mode ip
    timesync sntp
    sntp unicast
    no telnet-server
    time timezone 420
    no web-management
    interface 25
    name "-i- m_b_dc_c"
    exit
    interface 26
    name "-i- m_b_dc_c"
    exit
    interface 27
    name "-i- m_dr_c"
    exit
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1-24
    no ip address
    exit
    vlan 192
    name "MEDIA-NET"
    untagged 1-21,23-24
    ip igmp
    no ip igmp querier
    ip igmp version 3
    exit
    vlan 410
    name "Mgmt"
    tagged Trk22,Trk32
    exit
    vlan 1000
    name "CASINO-NET"
    tagged Trk22,Trk32
    no ip address
    exit
    spanning-tree
    no tftp server
    no autorun
    password manager
    password operator
    Thanks and regards,
    Set the login type to SSH on IMC
  • 3.  RE: Please help add aruba switch (2930f and 5406zl) to HPIMC
    Posted Jan 21, 2020 04:58 AM
    I known, i set ssh on IMC before
  • 4.  RE: Please help add aruba switch (2930f and 5406zl) to HPIMC
    MVP GURU
    Posted Jan 21, 2020 06:31 AM
    and always no working ?
  • 5.  RE: Please help add aruba switch (2930f and 5406zl) to HPIMC
    MVP GURU
    Posted Jan 21, 2020 07:46 PM
    Where are snmp related settings on posted switch running configuration? I mean...the only reference we see is "snmp-server community "kafka" operator" ...don't get me wrong but to connect to HPE IMC using SNMP (and SSH) you should enter few more commands, isn't it?
  • 6.  RE: Please help add aruba switch (2930f and 5406zl) to HPIMC
    Posted Jan 22, 2020 01:07 AM
    First verify ssh and snmp profiles from imc.
    Since you are not using tftp on switch side for file transfer you have to modify imc side as well to use sftp.
  • 7.  RE: Please help add aruba switch (2930f and 5406zl) to HPIMC
    Posted Jan 22, 2020 01:13 AM
    hope This video will help you
    https://youtu.be/LufZ-qUHN-c
  • 8.  RE: Please help add aruba switch (2930f and 5406zl) to HPIMC
    Posted Jan 22, 2020 01:54 AM
    On HPIMC, ssh/snmp templates config is correct.
    On Switch 5130,5940 everything is ok. The problem only Aruba switch
    And after I remove the password operator by cli: no password operator. HPIMC can be backup.
    Thanks everyone,
