Please help Aruba 650 License
  • 1.  Please help Aruba 650 License
    Posted Dec 15, 2019 10:33 AM
    Good afternoon,
    I bought an Aruba 650 controller with licenses on ebay, but then I accidentally entered the commands:
    # write erase
    # write erase all
    # reload
    The - write erase all command erased all licenses from the controller. Teams I took here - https://community.arubanetworks.com/t5/Wireless-Access/Reset-650/td-p/58592
    How can I restore the licenses for the controller I bought?
    As far as I understand, licenses were formed for this serial number, can they be restored ?
    If you need, I can send photos, both purchases, payment checks, and the one where the sticker with this serial number is on the back.
    Waiting for help from You, I hope you will help me.
    Vladimir
  • 2.  RE: Please help Aruba 650 License
    Posted Dec 15, 2019 10:42 AM
    type "dir" and see if there is a flashbackup.tar.gz file.
    If there is, type "restore flash", and reboot without saving
  • 3.  RE: Please help Aruba 650 License
    Posted Dec 15, 2019 10:52 AM
    Unfortunately, there is only this :(
    (aruba) >enable
    Password:*********
    (aruba) #dir
    -rw-r--r-- 1 root root 242308 Dec 15 18:35 123
    -rw-r--r-- 1 root root 9537 Dec 11 22:40 default.cfg
    -rw-r--r-- 1 root root 8255 Jul 30 2012 default.cfg.2012-07-30_2 2-53-37
    -rw-r--r-- 1 root root 9312 Jul 30 2012 default.cfg.2012-07-30_2 3-00-45
    -rw-r--r-- 1 root root 9114 Aug 21 2012 default.cfg.2012-08-21_1 5-51-18
    -rw-r--r-- 1 root root 10238 Sep 10 2012 default.cfg.2012-09-10_1 5-01-09
    -rw-r--r-- 1 root root 9148 Sep 13 2012 default.cfg.2012-09-13_0 4-19-29
    -rw-r--r-- 1 root root 10315 Sep 13 2012 default.cfg.2012-09-13_1 9-36-52
    -rw-r--r-- 1 root root 9146 Sep 13 2012 default.cfg.2012-09-13_2 0-19-12
    -rw-r--r-- 1 root root 11639 Sep 14 2012 default.cfg.2012-09-14_0 0-30-21
    -rw-r--r-- 1 root root 11639 Sep 14 2012 default.cfg.2012-09-14_0 1-05-58
    -rw-r--r-- 1 root root 11639 Sep 14 2012 default.cfg.2012-09-14_0 1-13-11
    -rw-r--r-- 1 root root 9118 Sep 14 2012 default.cfg.2012-09-14_17-41-28
    -rw-r--r-- 2 root root 8859 Dec 11 22:40 default.cfg.2019-12-11_22-40-34
    drwxr-xr-x 3 root root 0 Dec 11 22:38 fieldCerts
    -rw-r--r-- 2 root root 8859 Dec 11 22:40 original.cfg
    drwx------ 2 root root 0 Dec 11 22:38 tpm
    (aruba) #
  • 4.  RE: Please help Aruba 650 License
    Posted Dec 15, 2019 10:57 AM
    When I unpacked the controller, licenses were since the access point was included on poe, and now in poe such status: Unlicensed
