  • 1.  Please help Authentication Internal DB on 7005 Controller
    Posted May 20, 2016 10:10 PM
    I am new here and hope to be a big part of the community. I am hoping that someone here can guide me through he process of authenticating a WLAN against the internal DB. I have been at this for a few days and have had no success. Is there something that already exists that I can follow?
    I have a 7005 controller, 1 205 and 1 225 I am able to get both WLAN's working and in seperate VLAN's just cannot fiure out how to use internal DB for Authentication.
    Thank you
    #AP225
  • 2.  RE: Please help Authentication Internal DB on 7005 Controller
    Posted May 20, 2016 10:27 PM
    What kind of authentication?
  • 3.  RE: Please help Authentication Internal DB on 7005 Controller
    Posted May 20, 2016 10:36 PM
    Hello CJoseph,
    Thanks for jumping in. I suppose it is 802.1x internal DB. I just want to create users on the controller since I do not have a radius server. I want to enter the username and password similar to the process in the instant version. Hope this helps.
  • 4.  RE: Please help Authentication Internal DB on 7005 Controller
  • 5.  RE: Please help Authentication Internal DB on 7005 Controller
    Posted May 20, 2016 10:41 PM
    Awesome. Thanks a lot. I tried finding something like this.
  • 6.  RE: Please help Authentication Internal DB on 7005 Controller
    Posted May 21, 2016 08:29 AM
    Well gave it a go and no joy. I cannot connect. When I try with my tablet I get a wep prompt asking for a password. I am expecting a username and then password. What is the issue.
  • 7.  RE: Please help Authentication Internal DB on 7005 Controller
    Posted May 21, 2016 08:40 AM
    8) Click the SSID profile > Basic tab > Select the WPA2 authentication with AES encryption> Apply.
  • 8.  RE: Please help Authentication Internal DB on 7005 Controller
    Posted May 21, 2016 08:57 AM
    Thanks Colin
    Still no joy. Tablet is now EAP but asking for one line password.
  • 9.  RE: Please help Authentication Internal DB on 7005 Controller
    Posted May 21, 2016 09:26 AM
    What kind of tablet is this?
    What is the output of "show auth-tracebuf"?
  • 10.  RE: Please help Authentication Internal DB on 7005 Controller
    Posted May 21, 2016 10:08 AM
    Samsung tab s  I haven't looked at the cli. I have to come back to this later. Thanks for the help. Please stand by.
    UPDATE: It seems to be working. It was the app that I was using not presenting the logon. I used the OEM Samsung Android version and I was persented with the correct athentication page.
    Thank you Colin
    Joseph
