please help : i've problem with aruba 7205 controller
  • 1.  please help : i've problem with aruba 7205 controller
    Posted Feb 13, 2017 11:52 PM
    how to fix this problem??
    Initializing TPM and certificates [ OK ]
    Checking for configuration upgrade [ OK ]
    Starting OS services *******************************************************************************************
    cpu_1 received a bus/cache error(warning)
    CPU (XLP specific) registers dump: Node=0
    COP2: TxMsgStatus = 0x00000001, MsgStatus1 = 0x0f0f0000
    ICU: log0 = 0x00000000, log1 = 0x00000000, log2 = 0x00000000
    LSU: log0 = 0x00000000, log1 = 0x00000061b61c02d4
    SCU: log0 = 0x00004507, log1 = 0x71000000, log2 = 0x00000001
    TCU: reg0 = 0x00000000, reg1 = 0x00000000, reg2 = 0x00000000
    NBU: reg0 = 0x0000055c, reg1 = 0x70000000, reg2 = 0x00000001
    DRAM_A: reg1 = 0x00000000, reg2 = 0x00000000
    DRAM_B: reg1 = 0x00000000, reg2 = 0x00000000
    CPU: epc = 0x2ad481dc, errorepc = 0xffffffffc10069c4, cacheerr = 0x00000000
    LSU Cache Warning:
    log0=0x0000000000000000, phyaddr=0x61b61c02d4
    SCU Cache Error:
    log0=0x00004507, phyaddr=0x0000000171000000
    Way Info: <NULL>
    ErrType: External Error from Data or Completion for Fill
    ErrOpType: Load
    Uncorrectable: 1
    Overflow: 1
    Error Valid: 1
    NBU Cache Error:
    log0=0x0000055c, phyaddr=0x0000000170000000
    ReqSrc: IO
    ReqType: IO Read
    Overflow: 1
    Error Valid: 1
    Can not handle bus/cache error - Halting cpu
    thanks for help
  • 2.  RE: please help : i've problem with aruba 7205 controller
    Posted Feb 14, 2017 04:11 AM
    This does not look right. Please contact your Aruba partner or the HPE Aruba TAC through MyNetworking Portal: http://www.arubanetworks.com/support-services/contact-support/
  • 3.  RE: please help : i've problem with aruba 7205 controller
    Posted Feb 14, 2017 01:27 PM
    before report to support, can you tell me what the meaning about that error message?
    anyway thank for your information Herman robers
  • 4.  RE: please help : i've problem with aruba 7205 controller
    Posted Feb 15, 2017 04:21 AM
    Bus errors indicate some very low-level error; could be really corrupted firmware or even faulty hardware. The boot of your system stops in very early stages which is very uncommon and rare; therefore the advice to work with the Aruba TAC to find out what is needed to resolve.
  • 5.  RE: please help : i've problem with aruba 7205 controller
    Posted Feb 15, 2017 10:38 AM
    it looks like CPU problem, please contact Aruba TAC for futher information
