No, because the IAP is not a controller. For Instant mode, all APs need to be Instant (or Universal) models.
And I would be careful with buying IAP-205 as they are older technology, end-of-sale for 3.5 years now, don't get an upgrade to Aruba Instant 8.x, and will be end-of support in 1.5 year from now.
Original Message:
Sent: May 03, 2022 03:52 PM
Subject: Please I need help with AP-205 and Controller
Can I buy 1 IAP-205 and add the other AP-205s to that controller?
Daniel Ladeda
Original Message:
Sent: May 02, 2022 11:42 AM
An AP-205 access point indeed requires the use of a controller.
The 620 controller could be used, but it's indeed quite old, and to only ArobaOS code branch to support both 620 and AP-205 is 6.4, which is quite old as well, and no longer supported in case of issues.
You will need to purchase AP capacity licenses on that controller as well.
Onno Harms
Original Message:
Sent: Apr 29, 2022 01:57 PM
Hello, I am new to buying aruba equipment.
Recently my boss bought some model APIN0205 aruba antennas. The model that needs a controller
He bought them without knowing that this equipment was needed.
My question is, is there a way to install a driver on a computer without having to buy a subscription?
Another question, I saw a controller on ebay model Aruba 620. I know it's an old model, but can I use it to configure the APs? Do I need anything else to configure them? A subscription also to be able to use it?
I am very lost with these devices and the aruba phone support really doesn't help much.
Thank you!.
Daniel Ladeda
