PLINK / SSH Scripting to Mobility Controller
  • 1.  PLINK / SSH Scripting to Mobility Controller
    Posted Sep 18, 2013 11:56 AM
    Hi
    I would like to script an SSH connection and various commands to an Aruba controller for two reasons:
    1) Exporting local userdatabase on master and copying to TFTP, importing on local
    2) Exporting a 'show ap database' for a morning report to check that the AP's are up.
    When I run the following - plink -v -ssh USERNAME@IPADDRESS -pw PASSWORD -m commands.txt
    where commands.txt has
    en
    PASSWORD
    show ap database
    I get the error - "Keyboard-interactive authentication refused"
    Does anyone know why this might be, or could an alternative be suggested?
    Cheers
    Steve
  • 2.  RE: PLINK / SSH Scripting to Mobility Controller
    Posted Sep 19, 2013 02:34 AM
    Hi Steve,
    you can test the following:
    plink -v -ssh USERNAME@IPADDRESS -pw PASSWORD -batch < commands.txt > output.txt 2>&1
    commands.txt:
    en
    PASSWORD
    show ap database
    exit
    exit
    Then check output.txt for the results.
    Did you think about a "enable bypass" on your controller already? This will skip the 'enable/PASSWORD' command and after login you are in enable mode already.
    Frank
  • 3.  RE: PLINK / SSH Scripting to Mobility Controller
    Posted Sep 19, 2013 04:07 AM
    Thanks for the suggestion but no luck unfortunatly:
    Looking up host "IPADDRESS"
    Connecting to "IPADDRESS" port 22
    Server version: SSH-2.0-OpenSSH_5.8
    We claim version: SSH-2.0-PuTTY_Release_0.60
    Using SSH protocol version 2
    Doing Diffie-Hellman group exchange
    Doing Diffie-Hellman key exchange with hash SHA-256
    Host key fingerprint is:
    ssh-rsa 2048 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Initialised AES-256 SDCTR client->server encryption
    Initialised HMAC-SHA1 client->server MAC algorithm
    Initialised AES-256 SDCTR server->client encryption
    Initialised HMAC-SHA1 server->client MAC algorithm
    Using username "admin".
    Sent password
    Access denied
    Access denied
    Disconnected: Unable to authenticate
    Do you think 'enable bypass' would avoid this?
  • 4.  RE: PLINK / SSH Scripting to Mobility Controller
    Posted Sep 19, 2013 04:53 AM
    I don't think so, for me it looks like a wrong username or password.
    steveh_2001 wrote:Using username "admin".
    --- <snip> ---
    Sent password
    Access denied
    Access denied
    --- <snip> ---
    The 'Keyboard-interactive authentication refused' seems not to be an error but a information from putty.
    A successful connect looks like:
    Connecting to IPADDRESS port 22
    Using username "USERNAME".
    Sent password
    Access granted
    Opened channel for session
    Allocated pty (ospeed 38400bps, ispeed 38400bps)
    Started a shell/command
    Last login: Thu Sep 19 09:42:06 2013 from MYIP
    Sent EOF message
    (MYCONTROLLER) >en
    Password:
    Password:********
    (MYCONTROLLER) #
    (MYCONTROLLER) #show ap database
    AP Database
    Name              Group                       AP Type  IP Address    Status             Flags  Switch IP  Standby IP
    --- <snip> ---
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
           I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
           X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
           R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
           c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
           u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
           M = Mesh node; Y = Mesh Recovery
    Total APs:2
    (MYCONTROLLER) #
    (MYCONTROLLER) #exit
    (MYCONTROLLER) >
    (MYCONTROLLER) >eServer sent command exit status 1
    Disconnected: All channels closed
    xitConnection closed by foreign host.
    If I use a wrong password in the command line, it looks like your output:
    Sent password
    Access denied
    Access denied
    Can you try to login manually with your crendentials (plink -ssh USERNAME@IPADDRESS)? Are there any special characters in your password? For testing purposes try a simple password.
