Pls help me..
  • 1.  Pls help me..
    Posted Nov 30, 2012 08:19 AM
    please, this is very urgent, i have an aruba 650 controller which i configured with this ip addre 10.156.2.9,
    but the next day i wanted to login into the interface the ip addre i configured is not accepted.
    so i went to a command prompt to type ipconfig and to my surprise am seeing this ip address 169.254.193.8. i tried typing this ip in explorer but cant log into my aruba 650.
    pls what can i do
  • 2.  RE: Pls help me..
    Posted Nov 30, 2012 08:21 AM
    Can you reach the controller physically to plug in a console cable?
  • 3.  RE: Pls help me..
    Posted Nov 30, 2012 08:35 AM
    Yes i can
    what should i do next pls
  • 4.  RE: Pls help me..
    Posted Nov 30, 2012 08:45 AM
    You should login to the controller and see what ip address it has.
    Please do not post the same thing to multiple forums, because it will cause confusion.
  • 5.  RE: Pls help me..
    Posted Nov 30, 2012 08:55 AM
    ok Thks
    The current ip address is now 169.254.193.8, but i tried to login with the ip using internet explorer but is not accepting it.
    but when i ping the ip its replying.. what should i do pls
  • 6.  RE: Pls help me..
    Posted Nov 30, 2012 10:11 AM
    Hi The 169 address is on you laptop or desktop. This means it's not getting and ip-address from the dhcp server.
    That address is pingable.
    You need make sure that you laptop/is getting an ip address. You can try to give it a fixed address in the correct range.
  • 7.  RE: Pls help me..
    Posted Dec 02, 2012 10:34 AM
    From the console, run the command "show ip interface brief" and post the results.
