PoE AP 224 and 225
  • 1.  PoE AP 224 and 225
    Posted Jul 24, 2013 11:22 AM
    Hi my question is about the PoE at on the new APs 220 when I use the two ports with LAG I will need to have:
    1.-PoE 802.3at on both ports
    2.-802.3at on one and the other with 802.3af
    3.- Only one port with 802.3at.
    All this is because I want to have all the functionality on the AP with no restrictions.
    Thanks in advance.
    #AP225
  • 2.  RE: PoE AP 224 and 225
    Posted Jul 24, 2013 11:25 AM
    Number 3.
    Note that LAG is not supported in 6.3.0 software, but will be added in 6.3.1.
    /Onno Harms
    Aruba Networks
  • 3.  RE: PoE AP 224 and 225
    Posted Jul 24, 2013 11:33 AM
    Ok, Thank You so much.
  • 4.  RE: PoE AP 224 and 225
    Posted Jul 24, 2013 02:06 PM
    Can either port run POE? Is the ap220 able to have 2 ports with POE for redundancy?
  • 5.  RE: PoE AP 224 and 225
    Posted Jul 24, 2013 02:12 PM
    Yes, either port can take POE (but the AP can not draw current from both ports simultaneously). This can be used for redundancy, but the AP will reboot when POE power is lost on one port.
  • 6.  RE: PoE AP 224 and 225
    Posted Jul 24, 2013 02:15 PM
    Thank you for clearing that up for me.
    It would be nice if the ap wouldn't reboot if one of the links failed.
  • 7.  RE: PoE AP 224 and 225
    Posted Nov 13, 2013 10:40 AM
    Can the AP225 use both ports in a LAG to create 2 gig link with ArubaOS 6.3.1  to be active/active or will it be active/passive?
