PoE enable (?) on AP 61
  • 1.  PoE enable (?) on AP 61
    Posted Feb 18, 2013 11:15 AM
    My company recently acquired 10 AP 61 units, and 0 of them will power on via PoE (nor will they connect to my controller despite having purged the environment settings on them, but one thing at a time...).  I've found a power supply that will power them but in the dozens I've dealt with previously, I've never come across this.  Is there a setting in the AP config that switches PoE on and off?  Thanks in advance
  • 2.  RE: PoE enable (?) on AP 61
    Posted Feb 18, 2013 11:43 AM
    Like all aruba AP unit - the AP61 supporting 802.3af.
    (There is no such thing like ON/OFF switch for poe option in the AP)
     *be sure that the POE source is 802.3af and got enough output to operate the unit.
    *be sure that the eth cable u are using can transfer poe !! (not 4 wire cable)
    Datasheet info:
    INTERFACES
    • Network:
    - 1 x 10/100Base-T Ethernet (RJ45) , Auto-sensing link speed
    and MDI/MDX
    - 48 V DC IEEE compliant 802.3af Power-over-Ethernet (PoE)
    - Serial-over-Ethernet (SoE)
    • Power:
    - 1 x 5 V DC up to 1.5 A (for external AC adapter power)
    • Antenna: (AP-60 only)
    - 2 x RP-SMA multi-band antenna interfaces
    POWER
    • 48 V DC IEEE compliant 802.3af Power-over-Ethernet (PoE)
    • 5 V DC for external AC supplied power (adapter sold separately)
    • Maximum power consumption: 10 Watts
    link for datasheet:
     http://www.arubanetworks.com/pdf/products/DS_AP6061.pdf
    rgrds.
    me
  • 3.  RE: PoE enable (?) on AP 61
    Posted Feb 18, 2013 12:37 PM
    I am able to power other 61s, 60s, 65s, and 70s using the switch I am currently using.  We bought this lot of 10 APs, and they are the only units I've not been able to power with this PoE switch.  I also tried one into the controller itself and it didn't power.  It seemed very strange to me that all 10 of them behave this way, but I suppose I just have a bad bunch...  Anyone experienced something like this?  Where units will power off AC but not PoE?
  • 4.  RE: PoE enable (?) on AP 61
    Posted Feb 18, 2013 03:01 PM
    I hate to say it, but if it powers other AP61s, it should power all of them. :(
