POE Injector won't pass VLAN Information?
  • 1.  POE Injector won't pass VLAN Information?
    Posted Oct 23, 2014 03:11 PM
    We recently had a POE Injector that somehow would not pass the VLAN tags to the IAP103 we were setting up in a lab.  Everything worked when using a POE+ switch.  The injector was a PowerDsine PD9001.  Has anyone had this experience in the past, or was it more likely this particular injector has an issue?
    I find it hard to beleice that the Injector can't pass VLAN info, but can't find any info to show it is either known to work or known to not work.
  • 2.  RE: POE Injector won't pass VLAN Information?
    Posted Oct 23, 2014 05:40 PM
    have you tried another injector? the injector is simply a pass through device. it shouldn't control traffic.
    maybe validate the configuration?
  • 3.  RE: POE Injector won't pass VLAN Information?
    Posted Oct 29, 2014 08:44 AM
    Any luck?
