POE + Injectors
  • 1.  POE + Injectors
    Posted Apr 23, 2015 02:04 PM
    Can  "7001G  " Injetcors work with AP225  ?
    Or "9001G "  is a must ?
    It seems   Both Give 30 W ... what is the difference ?
    #AP225
  • 2.  RE: POE + Injectors
    Posted Apr 23, 2015 03:39 PM
    i assume, but not sure, it helps in such cases to provide all information and not make us guess, you mean these
    http://www.microsemi.com/products/poe-systems/pd-9001g-40-sp
    http://www.microsemi.com/products/poe-systems/powerdsine-7001g
    the 7001g is E(nd) O(f) L(ife) according to the site, so probably not a wise choice.
  • 3.  RE: POE + Injectors
    Posted Jun 05, 2015 06:04 AM
    i have soem old 7001g injectors
    can i use for my new AP225 ?
  • 4.  RE: POE + Injectors
    Posted Jun 05, 2015 08:12 AM
    it might, the specs say:
    The PD-7001G maintains the existing PoE standard (IEEE 802.3af) parameters with double the power.
    if you read the specs for the 225 it says:
    Power over Ethernet (PoE): 48 Vdc (nominal) 802.3af or 802.3at-compliant source - Efficient mode PoE – power save with 802.3af PoE and limited functionality
    * USB port disabled
    * Second Ethernet port disabled
    * 2.4-GHz 802.11n radio in 1x3:1 spatial-stream mode
    * 5-GHz 802.11ac radio operates without restrictions*
    Unrestricted functionality with 802.3at PoE+
    so although the injector isn't formally 802.3at it would provide enough power. of course the AP might do extra checking making it not work on the unrestricted functionality.
    don't believe you can 100% predict this without just trying.
  • 5.  RE: POE + Injectors
    Posted Jun 05, 2015 09:00 AM
    I have used both of these injectors and they power on an AP-225 but 802.11af will run the AP-225 in restricted mode
    No usb, 1x3 MIMO on the 2.4Ghz, no 2nd ethernet port, etc..
