PoE license on aftermarket Aruba 650
  • 1.  PoE license on aftermarket Aruba 650
    Posted Oct 09, 2017 10:05 AM
    I purchased a used aftermarket Aruba 650.  The PoE license is missing, and I'd like to have PoE on the unit.  According to the following document, the PoE license is no longer being "sold" as the 650 has been EOS'd:  http://www.arubanetworks.com/assets/support/EOS_Notice_xSec_PoE_Licenses.pdf
    Will I still be able to regenerate the License for this unit?  I have just registered and I'm waiting for the account to be accepted so I can go to http://licensing.arubanetworks.com.
    Thanks in advance for any assistance.
  • 2.  RE: PoE license on aftermarket Aruba 650
    Posted Oct 09, 2017 02:09 PM
    With recent code, POE should work without any license. Not sure when that was introduced though.
    What code version are you running?
    Note that you can't run anything after 6.4 on a 650 controller, which means that many newer AP models are not supported.
  • 3.  RE: PoE license on aftermarket Aruba 650
    Posted Oct 10, 2017 12:39 AM
    Hi Onno,
    OS version is running
    Controller > About
    Name: Aruba Operating System Software.
    Model: Aruba650
    Version: 6.1.3.5
    Compiled: 2012-09-28 at 07:46:05 PDT (build 35523) by p4build
    WebSite: http://www.arubanetworks.com
    Legal: Copyright (c) 2002-2012, Aruba Networks, Inc.
    In addition to the POE License I need ArubaOS 6.4.1.X on Aruba 650 to run AP 205, Is that possible? Where in your opinion I am not running anything after I upgrade V 6.4.X on Aruba 650?
    I include an image attachment indicating that my POE status is disabled.
