last person joined: 5 hours ago
PoE on 7010 controller %3F How many APs can I power up %3F
  • 1.  PoE on 7010 controller %3F How many APs can I power up %3F
    Posted Aug 12, 2014 02:50 PM
    I have 15 AP 225s. I need to power over ethernet to power them up. I have an Aruba 7010 controller. Do I need any licenses to enable the PoE ports on the 7010 ? Does a 7030 controller have PoE ports ? Is 1 7010 controller sufficient to power up the 15 APs ?
    Also another basic doubt: 1 PoE port can power up only 1 AP - is my understanding correct ?
    #7010
  • 2.  RE: PoE on 7010 controller %3F How many APs can I power up %3F
    Posted Aug 12, 2014 02:53 PM
    The 7010 has 12 PoE ports. Each port can provide power to one AP.
  • 3.  RE: PoE on 7010 controller %3F How many APs can I power up %3F
    Posted Aug 12, 2014 02:55 PM
    Thank you very much !!
    So, the 7030 does not have PoE ports correct ? Is there a controller that can power up all my 15 APs ?
  • 4.  RE: PoE on 7010 controller %3F How many APs can I power up %3F
    Posted Aug 12, 2014 03:10 PM
    Note the 7010 has a POE budget of only 150W, so almost more important than the number of POE ports is the overall POW power budget available.
    Regarding a controller to power more than 12APs, you should contact your local Aruba SE for details.
  • 5.  RE: PoE on 7010 controller %3F How many APs can I power up %3F
    Posted Aug 13, 2014 12:28 PM
    Thank you !!
    Another quick question ( Since I have not worked with a 7010 before)
    How do you enable PoE on a 7010 ? if I have the necessary licenses installed ? ( and if I do not have the necessary licenses installed)
  • 6.  RE: PoE on 7010 controller %3F How many APs can I power up %3F
    Posted Aug 13, 2014 12:30 PM
    There is no PoE license.
