Comware
  • 1.  PoE possible on all 48 ports?
    Posted Nov 21, 2019 01:51 AM
    Hello community,
    In my company we use a few HP 5130-48G-4SFP+ switches to where we connect all office computers and WiFi access points. All APs are connected through PoE and draws 13W each at most. I did some calculations and I think we're well within the capabitlity margins for what a switch could handle. No switch has more than 15 APs anyway.
    But I just want your support to confirm a good setup. Some experienced colleagues say the switches can't handle more than 5-10 APs through PoE.
    #PoE
    #AP
  • 2.  RE: PoE possible on all 48 ports?
    Posted Nov 23, 2019 06:48 AM
    that depends. Which HP 5130-48G-4SFP+ are we talking about? Is it the
    "HPE 5130-48G-POE+-4SFP+ EI (JG934A)"
    or the
    "HPE 5130-48G-POE+ 4SFP+ HI (JH324A)"
    because there is quite a difference.
    Anyways I'm guessing the former, the EI model. That one has a 370W PoE budget. So an equal distribution of Power pr port gives 370/48  = 7.7 Watts pr port.
    or if you talk full PoE+ (which is rated to 30W), you have enough power for 370/30 = 12 ports maximum.
    Normal PoE rating is 15.4Watts which gives 24 ports.
    You can tell your power-budget in detail by issuing the command.
    ] display poe pse
    Here is an example from one of our switches running 3113P05 (shipped software)
    <MY_UNIT>display device
    Slot Type                 State    Subslot  Soft Ver             Patch Ver
    1    5130-48G-PoE+-4SFP+  Master   0        3113P05              None
         EI
    <MY_UNIT>display poe pse
     PSE ID                           : 4
     Slot No.                         : 1
     SSlot No.                        : 0
     PSE Model                        : LSP7POEB
     PSE Status                       : Enabled
     Power Priority                   : Low
     Current Power                    : 104.7    W
     Average Power                    : 105.2    W
     Peak Power                       : 115.1    W
     Max Power                        : 370.0    W
     Remaining Guaranteed Power       : 370.0    W
     PSE CPLD Version                 : -
     PSE Software Version             : 146
     PSE Hardware Version             : 57633
     Legacy PD Detection              : Disabled
     Power Utilization Threshold      : 80
     PD Power Policy                  : Disabled
     PD Disconnect-Detection Mode     : DC
    <MY_UNIT>
    So, if your maximum usage is 15 APs at 13Watts, you should be well below the limit.
    NB: If you do have the HI-model, the PoE budget is depending on which power supply units you are using.
    it has a 720W option and a 1100W option (with 2 slots) which actually gives you the possibility for PoE+ on all 48 Ports.
    Regards
  • 3.  RE: PoE possible on all 48 ports?
    Posted Nov 25, 2019 03:47 AM
    Thank you Søren for your answer. I had a closer look at the switch in question last week, and it's the "EI"-version (model JG937A). Don't know how it differs from the JG934A you mentioned.
    So with the 370W PoE-budget we're theoretically able to connect up to 28 of our APs to 1 switch. Practically, we don't need to worry at all.
    I'm not at the site at moment, but will look at the power-budget when possible. Thank you for your help!
  • 4.  RE: PoE possible on all 48 ports?
    Posted Nov 25, 2019 04:11 AM
    Hi, about the JG934A vs. JG937A
    You're right, I must have copypasted from the wrong entry in the paranthesis. The JG937A is the PoE+ version with the 370W PoE budget, the JG934A is without PoE.
    Regards
