@DustinB wrote:
I have two new IAP-325 units.
One is conncted to a Trendnet PoE+ injector (TPE-115GI).
The other is connected to a Cisco WS-C3560X-48P-S switch.
Both power sources per thier documentation are full 30w PoE+ 802.3at compatible.
However, the power light on both access points are solid amber indicating they are running at 15 watt 802.3af power levels.
The Cisco switch has LLDP enabled and does recognize the IAP-325 as a class 4 device.
Here's the ouput of 'show power inline' for the connected interface:
Interface | Admin | Oper | Power (Watts) | Device | Class | Max
Gi0/12 | auto | on | 15.4 | Ieee PD | 4 | 30.0
And here's 'show lldp'
CiscoSw#sh lldp
Global LLDP Information:
Status: ACTIVE
LLDP advertisements are sent every 30 seconds
LLDP hold time advertised is 120 seconds
LLDP interface reinitialisation delay is 2 seconds
Am I doing anything wrong? Is there any change I need to do on the virtual controller to enable full 30w power for both access points?
Refernce Links:
TPE-115GI Specifications
Cisco 3560-X Series Switches
Thanks in advance!
Grab the tech support from the Instant AP and search for "Power Status". You should see the below if it is working. Please keep in Mind the "Operational State" is the current state and the "Current HW State" is what it gets on bootup before LLDP is negotiated...
Power Status
Operational State POE-AT: No restrictions (Overridden by LLDP)
Current HW State POE-AF: One Ethernet port disabled; USB port disabled; 1x3 chain for 2.4GHz; 3x3 chain for 5GHz
LLDP Negotiated POE Power 20.2W
What version of Instant is this?
