Here is my running config. I have Client A (10.10.40.92) connected to a dumb switch that is connected to radio FDC-ArubaB1P2P (10.10.40.96). Accross the air is radio FDC-ArubaB2P2P (10.10.40.95) connected to a dumb switch with Client B (10.10.40.85) attached to it. Client A and Client B cannot ping each other currently. Mesh is up and running and I have set the far radio FDC-ArubaB2P2P for Eth0 Bridging according to the manual.
Config:
9/15/2016 14:06:41 PM Target: FDC-AruabB1P2P Command: show running-config
version 6.4.4.0-4.2.3
virtual-controller-country US
virtual-controller-key 3b490805017cf618f3f3e52cac325f090b2eec924dc968a29e
name FDC-P2P
virtual-controller-ip 10.10.40.94
terminal-access
clock timezone Central-Time -06 00
rf-band all
allow-new-aps
allowed-ap f0:5c:19:c3:d0:8c
allowed-ap f0:5c:19:c3:d0:54
arm
wide-bands 5ghz
80mhz-support
min-tx-power 18
max-tx-power 127
band-steering-mode prefer-5ghz
air-time-fairness-mode default-access
client-aware
scanning
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
mgmt-user admin 2b167deb72769b5185f2f178a771f20d
wlan access-rule default_wired_port_profile
index 0
rule any any match any any any permit
wlan access-rule wired-instant
index 1
rule masterip 0.0.0.0 match tcp 80 80 permit
rule masterip 0.0.0.0 match tcp 4343 4343 permit
rule any any match udp 67 68 permit
rule any any match udp 53 53 permit
wlan access-rule FDCP2P
index 2
wlan ssid-profile FDCP2P
enable
index 0
type employee
essid FDCP2P
wpa-passphrase 170a9bd7911837d505146cf1ae7734d655600a5f9603218b
opmode wpa2-psk-aes
max-authentication-failures 0
rf-band all
captive-portal disable
dtim-period 1
broadcast-filter arp
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
auth-survivability cache-time-out 24
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
auto-whitelist-disable
https
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
wireless-containment none
wired-port-profile wired-instant
switchport-mode access
allowed-vlan all
native-vlan guest
no shutdown
access-rule-name wired-instant
speed auto
duplex auto
no poe
type guest
no dot1x
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 1
shutdown
access-rule-name default_wired_port_profile
speed auto
duplex full
no poe
type employee
no dot1x
enet0-port-profile default_wired_port_profile
uplink
preemption
enforce none
failover-internet-pkt-lost-cnt 10
failover-internet-pkt-send-freq 30
failover-vpn-timeout 180
airgroup
disable
airgroupservice airplay
disable
description AirPlay
airgroupservice airprint
disable
description AirPrint
