This information has been very helpful, thank you. But I think i'm stuck here. I can get the AP's to mesh, and in the controller I see both AP's online. The far ap (.91) is seen as up on my controller. But, when I try to configure and ping the managment interface on my far switch 68.3, i'm unable to ping the interface. I think my config on the Wired AP Profile is incorrect. Please advise.
VLAN 68 is switch Management
VLAN496 is AP VLAN
Switch port interface config:
Interface where AP's .90 and .91 are connected
Mobile1 switch 10.0.68.2
interface 8
name "10.110.96.90"
power-over-ethernet critical
poe-allocate-by class
tagged vlan 68,496
device-type network-device
Mobile 2 switch 10.0.68.3
interface 8
name "AP 10.110.96.91"
tagged vlan 68,496
Original Message:
Sent: Nov 21, 2023 03:26 AM
Subject: Point-to-Point Deployment with AOS 8 and 577 outdoor AP's
there are a lot of guides to find.
https://community.arubanetworks.com/discussion/howto-point-to-point-mesh-on-aos-85
https://www.arubanetworks.com/techdocs/ArubaOS_8.10.0_Web_Help/Content/arubaos-solutions/mesh/mesh-depl-solu.htm?Highlight=mesh
https://artofrf.com/2022/05/16/aruba-p2p-mesh-aos8/
Original Message:
Sent: Nov 20, 2023 06:42 PM
I'm searching for a deployment guide on a PTP setup. I need to extend my network using a PTP bridge (i think). I found some old info for AOS6, but nothing new for AOS8.
Any info is appreciated. Below is the old documentation.
https://www.arubanetworks.com/vrd/OPPDeployAppNote/wwhelp/wwhimpl/js/html/wwhelp.htm
Arubanetworks | remove preview |
