point to point link distance around 600M one is MSR2K with ANT-5314 and the Other is MST200 Issue?
  • 1.  point to point link distance around 600M one is MSR2K with ANT-5314 and the Other is MST200 Issue?
    Posted Dec 08, 2015 07:43 PM
    I have 1 MSR2K with ANT-5314 and 3M cables on site and the othe is MST200 I have tried to do getthe Best Link qouality was 60% and Linee of site is so clear and I used NA-HT20 Mode as 40 did form mesh the thing is the data rate iss too low like 39 M and when I ping from siite to other it shows ping pkt delay like 2000ms for ping only so whhat may cause this issue
  • 2.  RE: point to point link distance around 600M one is MSR2K with ANT-5314 and the Other is MST200 Issue?
    Posted Dec 08, 2015 11:29 PM
    If you have pictures of each end showing antenna alignment, cabling and connections to the APs, etc, that will help. You are sure the cables and connectors are 100% tight, there are no sharp bends in the cable, etc? What is the type of antenna cable (LMR200, LMR400, etc)?
    How are you testing throughput or are you just looking at the link rate? Can you get the show tech from the MSR2K and MST200 and send them to me at jhoward *at* arubanetworks *dot* com?
