Point to Point P2P Mesh Link between two AP 367 with instant
  • 1.  Point to Point P2P Mesh Link between two AP 367 with instant
    Posted Aug 17, 2018 03:54 AM
    The AP367 seem to be excellent to build a P2P link.
    Software = 6.5.x
    The setup seems to be easy:
    - connect both to one Switch
    - configure SSID
    - disable extended SSID
    - Configure ETH0 for bridge on the second AP 367
    After that mesh is working, but the second AP 367 doesn`t bridge packet to ETH0
    With no VLANS:
    in this mode (no trunk) the second AP 367 always disables the ETH0 and no traffic can pass
    With a TRUNK (more important):
    if you configure a trunk with wired profile, ETH0 is not disabled, but no traffic / no mac addresses are visible on the switch where ETH0 is connected.
    Here my wired profile:
    wired-port-profile P2P-Trunk
    switchport-mode trunk
    allowed-vlan 104
    native-vlan 106
    trusted
    no shutdown
    access-rule-name P2P-Trunk
    speed auto
    duplex auto
    poe
    type employee
    auth-server InternalServer
    captive-portal disable
    no dot1x
    Can anyone share a working config with me?
    What could be the problem?
    Thanks in advance
  • 2.  RE: Point to Point P2P Mesh Link between two AP 367 with instant
    Posted Nov 29, 2018 09:15 AM
    Vestra, did you ever get this working?  I'm trying to do the same with 377's and I'm a bit lost.
  • 3.  RE: Point to Point P2P Mesh Link between two AP 367 with instant
    Posted Nov 29, 2018 12:38 PM
    As far as i rememeber, there is problem with the Management VLAN auf the two APs, you will never see the management VLAN on the trunk port on the B-Side, all other VLANs in the trunk were working.
