Point-to-point setup with 2 MST200.
  • 1.  Point-to-point setup with 2 MST200.
    Posted Sep 27, 2016 09:19 AM
    I have a MST200 on each side.
    Configured the following:
    Host Name
    Mesh-ID
    Management IP
    Security Type
    Security Key
    Max Allowed Links.
    I can see the links up for each AP,  just not able to pass any traffic.  They are plugged into an ALcatel switch on boths sided to a trunk port.
    what am I missing on the AP side or dothe switch ports need a different config?
  • 2.  RE: Point-to-point setup with 2 MST200.
    Posted Oct 05, 2016 03:08 PM
    What is your ethernet configuration configured as? A sample would be:
    interface gigabit-ethernet 0
     mode gateway
     switchport trunk allowed-vlan 100,150
     switchport trunk native vlan 100
    interface vlan 100
     ip address 192.168.100.211/24
     mtu 1500
  • 3.  RE: Point-to-point setup with 2 MST200.
    Posted Oct 06, 2016 01:07 PM
    mode none
    switchport trunk allowed-vlan 1,3,7,202,302,620
    switchport trunk native vlan 7
    interface loopback 0
    ip address from-mac
    router-id
    interface vlan 7
    description data
    ip address 10.2.2.30/16
    mtu 1500
    I have changed the mode to gateway,  should this only be set on the one side?
    at each side the AP's are connected to an Alcatel-Lucent switch with the following ports vlans.
    MS-IDF4-6450-> show vlan port 1/5
      vlan     type      status
         3    qtagged   forwarding
         7    default   forwarding
       202    qtagged   forwarding
       302    qtagged   forwarding
       620    qtagged   forwarding
