Pointing Aruba controller to external DNS
  • 1.  Pointing Aruba controller to external DNS
    Posted Oct 23, 2012 03:31 PM
    Greetings,
    I have been tasked with changing the DNS on our Aruba Controller to an external DNS server.
    Does anyone know where I would make this change on the controller?
    Controller is in Los Angeles and external DNS server is in AZ.
    Any help would be appreicated.
    Arnie
  • 2.  RE: Pointing Aruba controller to external DNS
    Posted Oct 23, 2012 04:41 PM
    Hi.
    I'am not sure if it will do it (And if i understand your question right)
    But,If this is controller-based, you need to be running the latest ArubaOs 6.1.3.x and turn on DNS name resolution:
    Via CLI:
    config t
    ip dns-server 8.8.8.8
    Give it a try.
    me.
  • 3.  RE: Pointing Aruba controller to external DNS
    Posted Oct 23, 2012 05:33 PM
    Hi Kdisc - We are currently on 6.1.2.4. We had issues upgrading in the past and had to revert back to this version. Looks like there have been a few updates so I will probably revisit the update.
    So this option is not available on 6.1.2.4?
    Thanks!
    Arnie
  • 4.  RE: Pointing Aruba controller to external DNS
    Posted Oct 23, 2012 05:54 PM
    Just to clarify, are you trying to change the DNS your controller uses to look up records, or the DNS your wireless clients use?
