Poisoning the AP remotely
  • 1.  Poisoning the AP remotely
    Posted Sep 10, 2012 10:43 AM
    I have RAP's deployed at remote site and connects to controllers via public connection. Is there a way to poison a RAP (remove configs) remotely even if its not live on network. If yes, please let me know the procedure. Thanks
  • 2.  RE: Poisoning the AP remotely
    Posted Sep 10, 2012 12:21 PM
    You can re-provision the RAP with a non-existent controller IP, but it has to be online on the controller for the re-provisioning to work.
    If you want to remove entire configuration then you should reset the RAP for which you need physical access to the RAP.
    Hope that answers your question.
  • 3.  RE: Poisoning the AP remotely
    Posted Sep 10, 2012 02:01 PM
    Thanks for your reply. Actually, I am very much aware about re-provisioning the RAP while its live on network or removing the configs by getting into AP's console/hard reset to factory defaults.
    I was looking to poison the RAP while its in offline mode. I believe this is not possible and AP has to be online to modify the configs.
  • 4.  RE: Poisoning the AP remotely
    Posted Apr 02, 2013 03:38 PM
    We have come up with a procedure that accomplishes this to some extent.
    Create an AP group called "DisabledAP" or something similar.  Configure it with the following settings:
      rf dot11a-radio-profile "A_disabled"
         no radio-enable
      rf dot11g-radio-profile "G_disabled"
         no radio-enable
      ap wired-port-profile "Locked"
         shutdown
      ap-group "DisabledAP"
         enet1-port-profile "Locked"
    Then from the RAP Provisioning page, put the RAP in that group.  The next time the AP comes online, it will receive a new configuration which disables the ethernet1 port and both radios.
    Does that accomplish your goal?
