Comware
  • 1.  Policy Based Routing in A5820X
    Posted Mar 13, 2014 03:12 AM
    Hi All,
    Question regarding Policy Based Routing. First time I make use of the functionality and I wonder whether what I'm hoping to achieve is possible :) We are changing ISPs and I was hoping to test the new connection from a specific subnet. Routing is obviously set up to use the current ISP and I would like to make an exception to this.
    I'm looking for a way to route Internet bound traffic from Subnet A through a different (default GW) while sending (local) traffic to CorpNet down a different route.
    So, a combination of routes that I can define (CorpNet 10.x.x.x) and a general, catch all, defined range (Internet). I have got parts of it working, but I come up against different restrictions (e.g. only one policy per interface) and I can't seem to figure out how to build a configuration to handle the if/else, if you will, scenario of all traffic except for local (CorpNet) should use different gateway. I got the furthest by using an ACL if-match clause, but how do I combine or (possibly) build a destination is NOT CorpNet, then type rule. In my attempts I have associated my PBR with the vlan-interface of Subnet A.
    Best regards,
    Fredrik
    #A5820X
    #pbr
    #routing
  • 2.  RE: Policy Based Routing in A5820X
    Posted Mar 13, 2014 08:14 PM
    This is a pretty good step by step guide using the classifier and behavior mechanism:
    PBR example
    Cheers
    Ian
  • 3.  RE: Policy Based Routing in A5820X
    Posted Mar 14, 2014 03:38 AM
    I spent some more time on this "challenge" and believe I came up with a working configuration!
    Found a bullet in one sample configuration saying "If packets that match a policy node do not need to be forwarded according to PBR, specify deny match mode for the policy node". I replicated this in my configuraton and noticed that the switch started to treat my traffic the way I wanted.
    I have configured two ACLs, one matching traffic from subnet A to local (CorpNet) subnets and one matching traffic from Subnet A to any destination (Internet). I then built one PBR with two nodes based on the two ACLs, the first node is set to deny match mode. The other is set to permit and applies an alternative next-hop address (my new ISP).  Lastly, applied the PBR to the VLAN interface of Subnet A.
    /f
    acl number 3005
    rule 5 permit tcp source {Subnet A} 0.0.0.255 destination {CorpNet}
    acl number 3006
    policy-based-route PBR1 deny node 1
    if-match acl 3005
    apply ip-address next-hop {IP-address of A5820X}
    quit
    policy-based-route PBR1 permit node 5
    if-match acl 3006
    apply ip-address next-hop [NewISP_GW}
    quit
  • 4.  RE: Policy Based Routing in A5820X
    Posted Mar 15, 2014 01:14 PM
    Personally I would put these clients in their own VLAN and tag this all the way towards the new ISP (where it gets untagged), the routingtable would be handled as a VRF (vpn-instance in comware lingo) - but I assume your case was that these clients would still be able to reach the other resources of your internal network, you just wanted to change where their default route would go?
  • 5.  RE: Policy Based Routing in A5820X
    Posted Mar 17, 2014 02:33 AM
    Thanks for responding. Yes, that would definitely be an alternative and something to pursue - especially for me as it would give me a chance to get (more) familiar with VRF as a technology :) However, in this case you are right I need the clients to be able to communicate with other resources as well. It is more a matter of changing the default GW temporary during the transition to test the connectivity and configuration. Also, I don't have VRF running on the switch today so I believe it would require some additional configuration work that I will have to reverse later.
    Thanks again,
    Fredrik
