Policy Based Routing, more than one internet provider
  • 1.  Policy Based Routing, more than one internet provider
    Posted Jan 16, 2017 03:01 AM
    Hello Community,
    I have the following scenario. I have a master controller in my head quarter and a local controller with some AccessPoints in a branch office.
    Until now I have one SSID "internal" that is mapped to a VLAN on the local Controller, that works fine. The controllers default gateway is on the same interface but in a management-VLAN.
    But now I want to create 2 guest networks with 2 seperate WAN-Connections and captive portal. The controller have to act as router for the clients and have to do NAT. I saw the option "configuration > IP > next-hop". Is it right that I have to create 2 new entries "WAN1" and "WAN2" with the IP addresses of the router from the provider?
    And than create a List under "Security > Access Control" for the guest with a policy type route?
    I attach a file with a drawing of the planned scenario.
    Thanks for your help.
    Regards, Steffen
  • 2.  RE: Policy Based Routing, more than one internet provider
    Posted Jan 16, 2017 04:18 AM
    I'm not sure about the next-hop settings on the controller, however you can do what you're suggesting using External Services Interface (ESI) routing on the controller.
    http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/ESI.php
