Wired Intelligent Edge
last person joined: 2 hours ago
Policy-based routing question
This thread has been viewed 32 times
  • 1.  Policy-based routing question
    Posted Oct 13, 2021 07:20 AM
    Is it possible to create a policy-based routing entry on an HP 5406r2 L3 switch that:
    1) Routes a certain set of source addresses/clients (this is possible)
    2) Routes ANY IP traffic from these sources to a specific IP gateway (this is possible as well)
    3) Has a lower metric than the normal static route entries in the L3 switch? (can't seem to figure this one out)
    Any help is much appreciated.
    /Rasmus
    Rasmus Teglgaard
  • 2.  RE: Policy-based routing question
    MVP GURU
    Posted Oct 13, 2021 03:33 PM
    PBR should override the routing table for the matched traffic even if there is a static route.
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: Policy-based routing question
    Posted Oct 13, 2021 03:54 PM
    And there is no way around that?
    /Rasmus
    Rasmus Teglgaard
  • 4.  RE: Policy-based routing question
    MVP GURU
    Posted Oct 14, 2021 03:49 AM
    Hi Rasmus, since you're speaking about Routing Metric (path cost), the lower number represents the better route. You asked if the PBR routing has "lower metric" than (so precedence over) the normal static routing entries in the L3 switch...it means that the reason you're asking that is because you want that PBR routing takes precedence over the static routing. Isn't it? or are you asking for the contrary?
    If so, as Dustin explained, PBR will do exactly that...and - looking at the reason PBR should be implemented (as a mechanism to override normal routing matching particular conditions) - it looks pretty reasonable to me too. Doesn't it seem reasonable to you too?
    Davide Poletto
  • 5.  RE: Policy-based routing question
    Posted Oct 14, 2021 07:20 AM
    I want to use the static routes on the switch and AFTER that (it there's no matches) use the PBR. Isn't that possible?
    /Rasmus
    Rasmus Teglgaard
  • 6.  RE: Policy-based routing question
    Posted Oct 15, 2021 05:01 AM
    Hi Rasmus,
    As Davide and Dustin already explained, PBR is looked at before examining the RIB. In this way PBR is taking precedence over the static routes.
    So I believe that the answer of your question is: No, it is not possible.
    Stanislav Naydenov
