Poor Internet connection, disabling network. Android problem?
  • 1.  Poor Internet connection, disabling network. Android problem?
    Posted Jul 09, 2014 05:28 AM
    Hi all.
    I get this "Poor Internet connection" on Android devices and it's disabling network because of that and clients are complaining.
    We are using Captive portal that prevents on init-role such traffic.
    Just heard about this "problem" and I read about it from Internet, seems to be only Android related? It can be disabled from Android device but  clients dont know how to do that and so on.
    I know I could enable this check-address to passthrought from init-role but does anyone know the address where Android deviced are checking this "poor internet connection" ?
    BR,
    Joakim
  • 2.  RE: Poor Internet connection, disabling network. Android problem?
    Posted Jul 09, 2014 04:14 PM
    I to would love to know the answer to this, if there is a non-android solution.
    My work around was changing settings on the device.
