Wired Intelligent Edge
Poor switching performance with 2920 J9729A
  • 1.  Poor switching performance with 2920 J9729A
    Posted Jun 05, 2014 05:05 AM
    Hello Community,
    we have massive performance issues at one of our customers sites.
    Setup is shown in PDF-doc attached
    All switches are interconnected with LACP Trunks at 2GBit/s
    There are multiple VLANS
    QoS -DSCP
    Voice
    LLDP-MED
    Problem is:
    When we copy Data from one host to another we get transfer rates about max. 160Mbit.
    The two hosts are on the same switch and they are both connected at 1000FDx.
    Also when the two hosts are on different switches, the transfer rate is about 120Mbit
    Some config:
    hostname "DV1SW1"
    module 1 type j9728a
    trunk 43-44 trk1 lacp
    trunk 45-46 trk2 lacp
    trunk 47-48 trk3 lacp
    qos dscp-map 101110 priority 6
    qos type-of-service diff-services
    ip ssh listen data
    ip route 0.0.0.0 0.0.0.0 10.0.0.1
    interface 2
       lacp passive
       name "Sophos->WLAN"
       exit
    interface 3
       lacp passive
       exit
    interface 4
       lacp passive
       name "ImageQNAP"
       exit
    interface 5
       lacp passive
       name "AlphaBackup01"
       exit
    interface 6
       lacp passive
       exit
    interface 7
       lacp passive
       exit
    interface 8
       lacp passive
       exit
    interface 9
       lacp passive
       exit
    interface 10
       lacp passive
       name "ImageQNAP"
       exit
    interface 11
       lacp passive
       exit
    interface 12
       lacp passive
       exit
    oobm
       disable
       no ip address
       exit
    vlan 1
       name "DEFAULT_VLAN"
       no untagged 2,12,41
       untagged 1,3-11,13-40,42,A1-A2,B1-B2,Trk1-Trk3
       ip address 10.0.250.11 255.255.0.0
       jumbo
       exit
    vlan 100
       name "VOICE"
       tagged Trk1-Trk3
       ip address 10.1.1.11 255.255.255.0
       qos dscp 101110
       voice
       exit
    vlan 200
       name "WLAN"
       untagged 2
       tagged Trk1-Trk3
       no ip address
       exit
    vlan 300
       name "Fernwartung"
       untagged 12,41
       no ip address
       exit
    spanning-tree
    spanning-tree Trk1 priority 4
    spanning-tree Trk2 priority 4
    spanning-tree Trk3 priority 4
    spanning-tree mode rapid-pvst
    spanning-tree vlan 1 priority 1
    spanning-tree vlan 300 priority 1
    tftp server listen data
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    password manager
    other Configs are pretty much the same ...
    we have no idea what we've done wrong..
    Many thanks for some help ...
    Cheers ,
    Chris
    #2920
    #poor
    #performance
    #LLDP
    #LACP
    #QOS
    #issue
    Attachment(s)
    pdf
    setup.pdf   703 B 1 version
  • 2.  RE: Poor switching performance with 2920 J9729A
    Posted Jun 06, 2014 05:41 AM
    Hello community,
    any ideas ?
    Thanks in advance ,
    Cheers,
    Chris
  • 3.  RE: Poor switching performance with 2920 J9729A
    Posted Jul 19, 2014 06:57 AM
    HI all,
    unfortunally nobody replied to the thread.
    That's very sad :-(
    no matter what, we kind of solved the Problem.
    1. We've had multiple STP.Root changes .
    Set up a MSTP Configuration ported all other switches to mstp.
    select one switch to become root of the vlans of an mstp instance.
    Made the root-history a lot smaller.
    2. we had some trouble with jumbo-frames
    Enable jumbo on data vlan did the trick
    3.  for some reason the LACP trunks to the NAS didn't work.
    Ugrading to the newest beta-release of HP-OS did the trick.
    Some clients have had bad MTU values due to installing IPSEC-Clients (e.g. Cisco, LANCOM, etc.)
    So finaly a nice mix of stupid failures made me sleep very bad ...
    show tech all ...  a lot of time ... solution found.
