Wired Intelligent Edge
port-access clients disappearing on CX 6100
This thread has been viewed 37 times
  • 1.  port-access clients disappearing on CX 6100
    Posted Sep 09, 2021 10:30 AM
    I'm waiting on a call back from TAC, and was hoping the community might have some information. We have two CX 6100 switches both running 10.06.0140. We've seen this problem on other 10.06 releases as well.
    The issue is, that after a period of time, some port access clients (mac auth is where we've seen this so far) disappear from the switch. By that I mean that the command show port-access clients no longer shows them at all and we stop receiving any requests through clearpass. Rebooting the client doesn't help, nor does bouncing the port. Rebooting the switch does help.
    It can happen with a variety of clients and ports (all ports configured the same way) but the one we're seeing right now is on port 15, and the config on that is:
    interface 1/1/15
        no shutdown
        vlan access 1
        loop-protect
        loop-protect action tx-rx-disable
        aaa authentication port-access client-limit 32
        aaa authentication port-access dot1x authenticator
            eapol-timeout 2
            max-eapol-requests 3
            reauth
            enable
        aaa authentication port-access mac-auth
            reauth
            enable
        client track ip enable
    client track ip update-interval 60
    There's nothing regarding that port in the logs that I can see.
    Any ideas?
    Jordan Desroches
  • 2.  RE: port-access clients disappearing on CX 6100
    Posted Sep 13, 2021 01:24 AM
    Is there any traffic from mac-auth client reaching CX 6100? Can you please check below show command outputs?
    –show mac-address-table detail
    –show lldp neighbor-info
    –show cdp neighbor-info
    –show port-access clients detail
    –show aaa authentication port-access dot1x authenticator interface all client-status
    –show aaa authentication port-access mac-auth interface all client-status
    –show radius-server detail
    –show aaa authentication port-access interface all client-status
    Yash NN
  • 3.  RE: port-access clients disappearing on CX 6100
    Posted Sep 21, 2021 12:13 PM
    what did TAC say?
    had any evolution?
    we have the same problem here.
    hugs
    Paulo Kirchesch
  • 4.  RE: port-access clients disappearing on CX 6100
    MVP GURU
    Posted Sep 23, 2021 06:26 AM
    Hi all, yesterday Aruba released the ArubaOS-CX 10.06.0150 software build, specifically the Release Notes document about Aruba CX 6100 is available here.
    Maybe this new build could be tried to see if it solves/mitigates the reported issue.
    Davide Poletto
  • 5.  RE: port-access clients disappearing on CX 6100
    Posted Sep 23, 2021 08:05 AM
    Working with TAC we haven't gotten to the bottom of it yet. We've brought the systems up to 10.06.0140 (didn't help), and tried client-inactivity timeout none on the roles to try to help with quiet clients. We're still waiting to see if the client-inactivity timeout helps. We only have a few clients on the 6100 series, so some time can go by before we notice the issue. I'll bump the code version up to 10.06.0150 as it has several notes about authentication fixes.
    Jordan Desroches
