Hi, on a Cisco PIX I had a config where the WAN port was 1xx.1x.253.10 and the LAN subnet was 1xx.1xx.68.0/24 - a public IP range.
I had PAT setup so that I could open and close ports for the LAN subnet. By default all incoming ports were closed. If I opened the RDP port then RDP could be used from the WAN to connect to all of the machines on the 68 subnet. Similarly if I opened the SSH port, from the WAN I could SSH to any machine on the 68 subnet.
How do I set this up on a MSR1003-8?
#pat#firewall#publicIP
