port channel between CISCO WS-C6509-E and ARUBA 3600 ------ Input Errors on ARUBA
  • 1.  port channel between CISCO WS-C6509-E and ARUBA 3600 ------ Input Errors on ARUBA
    Posted Apr 23, 2014 02:55 AM
    hi,
    I have a lot of input errors for 5 ARUBA controllers with portchannel. All ARUBA controllers are connected to Cisco 6500. I am not sure when problem started, but probably after replacing Cisco 6500. Have you some idea, what can be checked or changed ?
    CISCO SIDE
    basic info
    cisco WS-C6509-E
    Version 15.1(1)SY1
    All interfaces which are connected to ARUBA have types - 10/100/1000BaseT
    configuration
    interface Port-channel201
     description EtherChan NYKARUBA01
     switchport
     switchport mode trunk
     switchport nonegotiate
    interface GigabitEthernet1/6/5
     description Portchan 201 to NYKARUBA01
     switchport
     no cdp enable
     channel-group 201 mode active
    interface GigabitEthernet2/6/5
     switchport
     no cdp enable
    ARUBA SIDE
    basic info
    Model Aruba3600
    Version 6.2.1.2
    interface port-channel 0
    790915827 input error bytes
    interface gigabitethernet 1/0
    790911428 input error bytes
    interface gigabitethernet 1/1
    7580 input error bytes
    configuration
            trusted
            trusted vlan 1-4094
            switchport trunk allowed vlan 1,1220,1230,1320,1330-1332,1420-1424
            no spanning-tree
            description "GE1/0"
            trusted
            trusted vlan 1-4094
            lacp group 0 mode active
            description "GE1/1"
            trusted
            trusted vlan 1-4094
    #3600
  • 2.  RE: port channel between CISCO WS-C6509-E and ARUBA 3600 ------ Input Errors on ARUBA
    Posted Apr 23, 2014 05:29 AM
    Can you make sure that the same VLANs on the Cisco side are allowed on the Aruba side?  I only see allowed VLANs on the Aruba side..
  • 3.  RE: port channel between CISCO WS-C6509-E and ARUBA 3600 ------ Input Errors on ARUBA
    Posted Apr 23, 2014 06:26 AM
    I added ´´switchport trunk allowed vlan 1,1220,1230,1320,1330-1332,1420-1424´´ on cisco side, but there still input errors on ARUBA side.
  • 4.  RE: port channel between CISCO WS-C6509-E and ARUBA 3600 ------ Input Errors on ARUBA
    Posted Apr 23, 2014 08:25 AM
    You probably do but make sure you are using Aruba recommended gbics on the controller
    http://www.arubanetworks.com/support-services/interoperability/#SFP-XFP
  • 5.  RE: port channel between CISCO WS-C6509-E and ARUBA 3600 ------ Input Errors on ARUBA
    Posted Apr 28, 2014 06:28 AM
    I am using 10/100/1000BASE-T (RJ-45), not SFP.
  • 6.  RE: port channel between CISCO WS-C6509-E and ARUBA 3600 ------ Input Errors on ARUBA
    Posted Jun 04, 2014 04:04 AM
    I have two customer which have same physical network connection.
    It means that there is Cisco Switch 6500 connected via Port-channel to ARUBA 3600.
    ARUBA 3600 - portchannnel 0 (gi 1/0 + gi 1/1).
    I cleared counters before 6 six days and there is especially a lot of input error in device NYNARUBA01.
    Do you think that it is ok, when there is a lot of input errors? or maybe is it normal behaviour ?
    (NYNARUBA01) #show interface gigabitethernet 1/0
    Last clearing of "show interface" counters 6 day 0 hr 47 min 53 sec
        44333653 packets input, 11224431154 bytes
        Received 4048942 broadcasts, 0 runts, 0 giants, 0 throttles
        3123049 input error bytes, 0 CRC, 0 frame
    (NYNARUBA01) #show interface gigabitethernet 1/1
    Last clearing of "show interface" counters 6 day 0 hr 47 min 57 sec
        18386869 packets input, 4708390157 bytes
        Received 481551 broadcasts, 0 runts, 0 giants, 0 throttles
        20 input error bytes, 0 CRC, 0 frame
    (HAN-RES-029-ARUBA1) #show interface gigabitethernet 1/0
    Last clearing of "show interface" counters 6 day 0 hr 50 min 0 sec
        131698854 packets input, 141993577801 bytes
        Received 1474241 broadcasts, 0 runts, 0 giants, 0 throttles
        17541 input error bytes, 0 CRC, 0 frame
    (HAN-RES-029-ARUBA1) #show interface gigabitethernet 1/1
    Last clearing of "show interface" counters 6 day 0 hr 50 min 1 sec
        55661025 packets input, 10655092070 bytes
        Received 1708014 broadcasts, 0 runts, 0 giants, 0 throttles
        51681 input error bytes, 9 CRC, 0 frame
  • 7.  RE: port channel between CISCO WS-C6509-E and ARUBA 3600 ------ Input Errors on ARUBA
    Posted Jun 04, 2014 04:27 AM
    is ARUBA using only LACP protocol ? can I set static port-channel ?
    probably I will try to turn off portchannel and I will try connect only one physical cabel.
  • 8.  RE: port channel between CISCO WS-C6509-E and ARUBA 3600 ------ Input Errors on ARUBA
    Posted Jun 04, 2014 04:33 AM
    If  it is a trunk, please make sure the allowed vlans match on both sides.
  • 9.  RE: port channel between CISCO WS-C6509-E and ARUBA 3600 ------ Input Errors on ARUBA
    Posted Sep 24, 2014 06:55 AM
    I found root cause. It was STP. I added bpdu filter on CISCO switchports + I denied STP on ARUBA and then input errors on ARUBA interfaces disappeared.
