I am experiencing a problem creating a port channel in AOS 8.6
Interface 0/0/4 and 0/0/5 work okay as non LACP 10 G trunks. However, when in a LACP active trunk group they don't work. All looks to be okay with the config. I must be overlooking something simple. I've taken 0/0/4 out of the port channel group, and left the md working on 0/0/4. The only thing I haven't tried is to convert the interfaces to access before entering them into the port channel. Any pointer on the setup?
Config for port channel 1, without 0/04 which is been put back into production:
Port-Channel 1 is administratively up, Link is up, Line protocol is down
Hardware is Port-Channel, address is 00:0B:86:B8:1D:C7 (bia 00:0B:86:B8:1D:C7)
Description: Link Aggregate (LACP)
Spanning Tree is Discarding
Switchport priority: 0
MTU: 1500 bytes
Member port(s):
GE 0/0/5, Admin is up, Link is up, Line protocol is down
Speed :0 Mbps
Interface index: 8194
Last clearing of "show interface" counters 10 day 16 hr 18 min 46 sec
link status last changed 4 day 3 hr 14 min 50 sec
2794142 packets input, 1055694895 bytes
Received 563756 broadcasts, 0 runts, 0 giants, 0 throttles
0 input error bytes, 0 CRC, 0 frame
451748 multicast, 2230386 unicast
3399114 packets output, 1443483042 bytes
0 output errors bytes, 0 deferred
0 collisions, 0 late collisions, 0 throttles
Port-Channel 1 is TRUSTED
Statistics for member port: GE 0/0/5
Switchport: Enabled
Administrative mode: trunk
Operational mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 140 (mobility management)
Trunking Vlans Enabled: < correct list of VLANS >
Trunking Vlans Active: < same as correct list of VLANs above >
(nodename) [MDC] *#
(nodename) [MDC] *# show interface port-channel 1 trusted-vlan
Trusted Vlan(s)
1-4094
Racingyacht
